Question about Mitsubishi VS-50605 50" Rear Projection Television
How can I disassemble a Mitsubishi VS-50605 rear projection TV so I can get it out of my basement?
  • 1153 Answers
SOURCE: Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Posted on Nov 26, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi vs-50703 65 in. Rear
that model is famous for the CRTs leaking coolant onto the main board near the vertical output Ic and causing the set not to power up. Check the fuses on the main board and also look for evidence of leaking fluid which often appears as a stcky residue it should appear shiny with a bright flashlight.
Posted on Apr 22, 2008
icansolve
  • 45 Answers
SOURCE: Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Posted on Dec 18, 2008
VOTIT
  • 2071 Answers
SOURCE: no picture . tvturns, immediately turns off
Your TV set is in protect mode .To protect further damage of some component parts.There is something internal problem inside maybe there is a shorted.
Good luck;
Regards:
VOTIT
Posted on Jul 01, 2009
Ecollier2012
  • 3459 Answers
SOURCE: i have a mitsubishi vs-50605 in rear projection
You have to remove the front screen or back panel. Every set is different.
convergence is in the menu - if you have the original remote.
Posted on Sep 06, 2009
No picture . tvturns, immediately turns off
Good luck;
Regards:
VOTIT
Jul 01, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Vs-50605 HD Ready Mitsubishi 50"
with the age of this set it is probably component input for the hd,,remember 480p is considered hi def..
Nov 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
How to take off protection screen of a Mitsubishi VS-50605 50 in. Rear Projection
Usually have to pull the speaker grill off (friction fit), there will be some screws under the bottom edge of the screen, if there are wires you may have to unhook them, sometimes the plugs are behind a pannel that gets unscrewed from the front. The frame will come apart to drop the new screens in.
Jul 14, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
