Question about Smith 2hp Pool Pump Motor A O Electric Pool Motor Replacement for 48y Square Flange Usq1202
Wiring of 2hp motor
The reconditioned spa pump motor is a 230 volt single phase motor & has 3 wires 1- yellow 1-white 1-black wire haging out of the motor enclosure & when connecting the yellow & black to 1- hot conductor & 1- hot conductor to the white wire the motor will not start it will just hum until the thermal overload kicks the motor circuit off.Is it possible the capacitor is bad or could it be miswired when it was reconditioned?
  • 4,300 Answers
You need to take advice from the motor manufacturer or reconditioner to ensure you are wiring it correctly.
Typically a basic single phase motor will have a start winding and a run winding. That usually makes four wires for a reversible motor but that can be cut to three if the motor must run in one direction only so the three wires would be start, run and common.
The run is connected to the hot side of the supply and the start similarly connected to the hot side except the start capacitor will be in series. The common wire will require connecting to a neutral and of course the motor body will need a ground unless it is double insulated.
It should be possible to sort which is which using a sensitive ohmmeter.
Posted on Jul 03, 2017
3 Suggested Answers
  • 1902 Answers
SOURCE: Hi I am replacing pool pump motor (O A Smith
In this case you are going to be better off consulting a electrician to help you with this issue. There are to many risk involved in getting someone to assist you over the internet with this. If someone tells you the wrong wire placement and you get hurt or pop the fuse in your house you are now looking at that much more work,
Posted on May 05, 2010
  • 2100 Answers
SOURCE: Pool pump 3/4 hp wiring
I think the lug with no screw is for 110 volt? Don't know, but your 2 wires in, black and red are both hot, each one to the lugs,line 1 and 2, the bare wire gets bolted on outside of the motor and jumped to another ground somewhere, and the white wire, goes to a lug marked B?,,, check that one. I went to the web site and they want you to know if you do it wrong, no guarantee, so check out the frame number, then look up your motor and go by the label. Hope this helps.
Posted on May 06, 2010
Testimonial: "Thank you this was all I needed was the link that you give me. It showed the wireing digramof the motor. Thanks Max B"
How do i wire a 2hp 1ph. motor that is 115/230 volt to run on 230 volt?
Did you check under the connection plate for a wiring diagram? If it is single phase it will only have three wires to it, but 4 connections. There will be a common ground wire, a common neutral wire and then with the live wire you have the choice of putting it on the 110 connector or the 230 connector.
I also found this image.
Oct 11, 2015 | Saws
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
What is the difference between neutral and phase?
neutral is the white wires on each power phase phase is the number of hot lines to run pump 120 volt 1 phase 220 volt 2 phase 3 phase has 3 lines to it let electrician handle this
May 31, 2012 | Waterway 5 Hp 230 Volt 2 Speed Side...
My pool originally had a 2 speed AO Smith pump motor. Several years back it was replaced with an AO Smith single speed motor. I am replacing that motor with a new AO Smith single speed Centurion Switchless...
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
May 23, 2011 | AO Smith 2 hp 3450rpm 56C Frame 230 Volts...
HELLO , i have a Powcon 300 SM i have understood how to change from 460 volt to 230 volt three phase but i can not figure out how to change the whole machine over to single phase 240 ...
Look for a "Phase Converter" at Harbor Freight or look in You Tube for info on building one. If you have a lot of welding to do, I would get a better quality converter than they have at HF.
Nov 29, 2017 | Computers & Internet
Wiring a new pump but the wires are different colors
Neutral should be white. To be sure pull the cover plate off the *********** of the motor on the back side of the plate it will have the wires color coded for which wire is neutral and which is hot. Normally Black would be hot and the yellow wire could be second speed so if you look on the plate on the new motor you will be able to see the wiring diagram. This is assumeing it is a 110 Volt motor single phase.
May 28, 2010 | Aqua Flo Flomaster 1.5 H.P. 2 Speed Fmhp...
I have 1 black, 1 white and 1 green ground on pressure switch. ?
Black & White would both be 115v on a single phase 230 circuit, green would be ground.
Jul 20, 2009 | Ingersoll Rand - Rand Type - 30...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
Smith 2hp Pool Pump Motor A O  Electric Pool Motor Replacement for 48y Square Flange Usq1202 Logo
1,059 people viewed this question
Top Smith Pool & Spa Experts
Mike Squire
Jay Finke
Jay Finke
Paul Carew
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
