I got an error message, "stop: 0x00000024 (0x00190203, 0x833E4AB0, 0xC0000102, 0x00000000)" and can't do anything to get it to boot up in Windows. I even tried reinstalling Windows XP with no luck. Is it possible to restore my laptop without losing everything? It wouldn't run chkdisk so I used scandisk and it found "physical damage on drive A that it cannot correct. ScanDisk cannot repair damaged cluster 2 because other damage to drive A prevents it." When I click okay, it says that "At least one area of drive A has sustained physical damage. Although such damage might be caused by an isolated incident such as a power failure, it is often a sign of impending hardware failure." It says to back up my files but I get get into Windows to back up anything.
  • 4,281 Answers
For that you need to buy recovery software.
You can buy it from below link.
click here
Then connect your harddrive to another computer and install this software on that computer then you can recover your data with this recovery software.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 12, 2010
Computer won't boot stuck in Error RecoveryScreen won't go any further
You should be able to do a clean install of Windows. Just insert the installation disc and press any key when indicated. Optical drive needs to be the first boot option. Go into BIOS and change it is not.
As for disc, you have to use the same Windows version as indicated on the MS Product Key sticker, because of the serial number.
May 24, 2013 | Toshiba NB205-N210 Netbook
El1358g-51w loaded drivers so far and then stopped error message read i had to restart and it would load and did not
You will have to reboot into safe mode to remove those drivers from the device manager and then reboot and allow windows to find the drivers it wants and not the drivers you think are the right ones because sometimes a flaky driver will stop windows cold and lock it into a loop forever.
If you do not know how to boot into safe mode, when you turn on your computer, the moment you see anything on your monitor start rapidly pressing the F8 key until you get a boot screen that has a choice of booting into safe mode, then follow the directions and when you finally get into windows go to the device manager, (in most windows will either be accessible from the control panel or from the control panel then clicking on system>then hardware tab>then device manager button.
Nov 30, 2012 | E-Machines eMachines Desktop PC
Windows 7 wont start
LOL, I wouldn't give up my windows xp for anything else.
OK, what does it do that requires you to keep trying to get it to boot? Are you getting any error messages? Is it just stopping or freezing someplace in the boot cycle? Is it doing that stupid Startup Repair? What is it doing that causes several tries to get it to boot?
Apr 22, 2012 | E-Machines Computers & Internet
The error message says fatal system error.
Hi. The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Booting the computer to its Last known good configuration will resolved the issue. Please see procedure below:
Turn of the computer
Keep on tapping F8 key the moment you press the power button
You should be getting a advanced boot screen
Select Last known good configuration from the selections then hit enter
Computer should be booting up by now to windows
All the best!
Jul 24, 2010 | Acer TravelMate 2480-2968 Notebook
I can't start my computer. Message "start your computer in safe mode"appears on the screen and than screen goes black and after few seconds the previous message appears on the screen.It's like a vicious...
Assuming Win-XP? ... When the computer is booting up (before windoes graphics) keep on tapping the F8 key to boot into safe mode. You should then be able to identify what is stopping Windows from booting properly.
- Have you just installed any software / drivers?
- Check the error logs and device manager to see if anything is wrong
Good Luck
Jan 18, 2010 | Toshiba Satellite P35-S611 Notebook
Won't boot
Here is the cause, and I think you will have to re-install the operating system. Not knowing your machine model number, I have no idea if the operating system recovery is imbedded in the hard drive or not.
http://www.geekswhoknow.com/articles/stop-0x00000024-0x0000024-0x24-ntfs-file-sys-error-code.htm
If you receive a blue Dell line across the top of the screen during power up, press F11 to see if you can get into the recovery mode. If so, just follow the instructions.
Mar 18, 2009 | Computers & Internet
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Umountable boot volume
power down the pc unplug it and when it restart up go to F2 and see if you booting in c or in your cd rum try this
Dec 20, 2008 | Dell Dimension 4300S (Refurbished)...
Lxczpswx.exe error when booting up windows
Try this:
Click on START, click on RUN
A small window opens, delete anything that may be typed in it and then type this -
regsvr32 /u c:/windows/system32/spool/drivers/w32x86/3/lxczPSWX.EXE
click OK
Oct 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
