Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon mp150 saying e2, how do i get rid of it?
  • 4,041 Answers
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
Posted on May 12, 2010
2 Suggested Answers
SOURCE: Canon Pixma Mp150 keeps having E2 flash
My E2 problem turned out to be a few rails of staples and an earring back stuck in the paper feeder at the back. Removed the staples but the earring back is still in there somewhere....lol. Printer works fine after dislodging all kinds of stuff.... :)
Posted on Dec 08, 2009
PRINTER mp145 is displaying E2 error message saying that no paper, how ever im not going to use printer, instead i want to use scanner but with E2 error message i cannot scan so pls give me one solution.
Do you mean E,2,2 indication? It means Carriage error.
Replace the following parts in the given oder
Timing **** strip film Logic board ***'y Carriage motor (Main unit) Carriage unit (Main unit)
May 15, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
May 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have canon pixma150 and on display is always sign E and than two and so on. what is that - E2?
The error E2 means the printer is out of paper.
Reload paper in the auto sheet feeder and press the "Black" or "Color" button.
Mar 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have an error E2. I have tried to reset the
E2 just says to insert paper and press OK, for some reason the paper is not feeding or the sensor inside is not seeing the paper. Check inside where the paper goes for any obstruction, sometimes ink pens, paper clips, jewelry, etc... fall inside the back and stop the paper from feeding. If your printer has 2 choices for paper make sure the paper is in the right tray and select the correct tray.
Feb 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Canon Pixma MP150 printer LCD shows error E2 ,also receiving service error 5100,on Windows repeatedly.Have changed the required ink cartridge .unable to print. Also unable to run maintenance tasks...
It is problem any hardware is not work properly.If you are a technician please service your printer properly.Clean all surface, blowing it.when you show E2 press black or color key
Dec 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E2 flash error
Make sure that you have to pressed the "feed switch" bottom and make sure the light that appears is compatible with the place to puts the paper in.
Good luck, I faced the same problem the first time I bought my canon.
Aug 10, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I just solve my first problem for code e8, thanks. after i start printing another problem came and keep flashing e2 and e7. what shall i do? got plenty pending printing to do. thanks
From Canon tech site.1. Load paper correctly then press Black or Color button (MP150)
2. Press ON/OFF switch to reset the multifunction device
3. Remove Packing Material MP150 / MP170 / MP450
4. Removing obstruction from ASF then press Black or Color button (MP150)
5. Reseat ink cartridge (MP150 / MP170 / MP450)
6. The MP150 may require repair
Jun 20, 2009 | Canon PIXMA MP150 All-In-One InkJet...
ERROR CODE CANNON MP150/MP160
your mother should make sure that she has pressed the "feed swich" bottom and make sure the light that appears is compatabile with the place she puts the paper in. Good luck, I faced the same problem the first time I bought my canon
Aug 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
157 people viewed this question
old marine
old marine
