Question about Janome Mini Compact
Won't sew My Janome Mini sewing machine will not sew,I've changed thread re-wound the bobbin. replaced the needle still nothing. It was working fine I took a break from sewing and when I returned to the sewing table, It wouldn't sew any more. Any help would be appreciated. Thank you
  • 92 Answers
Give more info. Do the motor turn? is the machine stuck? or do every thing work but it do not sew onto the material? We got 9 machines that we work with every day and we repair it as well. E-Mail me and give more info and i am sure I can help. Willem an Fienie South Africa ( wcbotha@yahoo.com )
Posted on May 12, 2010
3 Suggested Answers
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
Janome sew mini needle not picking up bobbin thread.
Hi: Is this a needle provided with the machine as new? What type of fabric are you sewing... have you tried a different fabric? Is the bobbin placed into the machine correctly with it unwinding in the right direction?
Aug 10, 2012 | Janome SEW MINI Mechanical Sewing Machine
Bobbin won't move
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
Janome 2212
try changing needles-flat side to the back of the machine
check for any burrs around the needle plate area
check to make sure the tension is not to tight
check to make sure the bobbin is wound correctly & inserted correctly in the bobbin case
Mar 26, 2012 | Janome 2212 Sewing Machine
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
Upper thread not engaging bobbin thread...
Hiya Kandie. Usually when you can't pull the bobbin through, the wrong size needle is in, try a different size needle. Hope I was some help for you.
Feb 08, 2012 | Janome SEW MINI Mechanical Sewing Machine
When I sew, the topstitch looks fine but when I turn it over, there are large loops of thread?
clean under the needle plate where the feed dogs are for lint
also clean in the bobbin area for lint or loose threads
also check the top thread tension--try 3 or 4
rethread the machine top thread & bobbin
make sure the bobbin is wound correctly- if it's not wound correctly it will cause sewing problems
also change the needle
Nov 17, 2010 | White Sewing 1418 Mechanical Sewing...
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Janome mini sewing machine not picking up thread
Is it under warranty? A dealer should be able to check it out without cost to you. Do you have the bobbin in properly.
Oct 18, 2008 | Janome Mini Compact
Janome Mini Compact Logo
564 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
