Question about Dell 1704FPTt 17" TFT LCD Flat Panel Monitor
Why don't the ports on the monitor work?
There are 8 ports listed but they are using 0 power. Is there a secret to activating the other ports on the side of the monitor?
  • 11,361 Answers
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
Posted on May 13, 2010
2005 Gmc Sierra 5.3 litter SLT. Wire diagram for passanger side power window. No power to door.
Do the power door locks work for that door ? Does you vehicle have door courtesy lights , turn signals on the mirror ? If your vehicle has these other options an they work , you have power to the door . There is an electronic module inside the door ,called passenger door module ! where did you check for power at , the window switch ! These are computer controlled an you would only see a few volts when pushing the switch !
7
  1. Monitor the passenger front window status in the passenger door module inputs list.
  2. Activate the passenger power switch on the passenger door module in the up and down positions.
Does the window status data parameter change accordingly?
Go to Step 8
Go to Step 15
8
  1. Monitor the passenger front window status in the driver door module inputs list.
  2. Activate the passenger front power window switch on the driver door module in the up and down positions.
Go to Step 9
Go to Step 16
Operate the passenger front power window in the UP and DOWN directions from the master switch.
Does the passenger front power window operate properly from the master switch?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 5
  1. Install a scan tool.
  2. Monitor the window lockout data parameter in the driver door module inputs list.
  3. Activate the window lockout switch to both the On and OFF positions.
Does the window lockout data parameter change state appropriately?
Go to Step 5
Go to Step 16
Your best bet is to take this to dealer or a ASE certified repair shop.
Jun 14, 2015 | GMC Cars & Trucks
Tip
Siemens MODELS CODES & DESCRIPTIONS
*#0003*(secret code 8 digits)# All Siemens Phones: Service Provider Unlock
Siemens S25/C25
SP unlock *#0003*(secret code 8 digits)#
Show IMEI code: * # 06 #
Resets language to automatic selection : * # 0000 # then Green button
Pin Out
Data Cable schematics
Phone's connector pin-out:
1- GND
2- SB
3- POWER
4- NC
5- TX
6- RX
7- CLOCK
8- DATA
9- GND MIC
10- HF MIC
11- AUDIO
12- GND AUDIO
Siemens S1/S3/S3 Com
To view the software date and else with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey.
To view some other stuff with S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey twice.
To view the software date with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM installed menu 98 and left softkey twice.
ACTIVATE MONITOR MODE
Siemens S1/S3
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, Hang-Up Button (Red Handset key)
Siemens S3 COM/S4
Menu, 9 (Phone Options), 7 (Phone Status - 8 on Some), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Note: Now Monitor should appear at the bottom of the Network Options menu.
MONITOR MODE
Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes
Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals.
Test Mode Indicators: (* = only available when call in progress )
CH Channel Number
RX Signal Strength (dB)
N NCC (Colour Code)
B BCC (Colour Code)
CI Cell ID (in Hex)
C1+ How long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01) and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
POWER table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S1/S3
Here's a trick to play Tetris, also known as Klotz on a Siemens S1.
Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps.
1: Choose F 9 (function settings)
2: Choose send own number and push the right button for choose.
3: Push 9
USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4.
[I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparently someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all.]
Siemens S3 Comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
Hang-Up Button. (Red Handset key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE
Siemens S4/S4 Power
In phonebook under "Own Phone No." enter +12022243121 (which is the number to the White House) and you'll get a greeting from the people who programmed the phone.
MONITOR MODE
The Siemens S4 series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Now "Monitor" should appear at the bottom of the Network Options menu.
CH Channel Number
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
RXAM Reeceive signal strength cut-off point
PL* Power Level
Power Table
Siemens S6/S10
In Phonebook, store as your own number: +12022243121
Then you get the sun and two palms in the display, also a greeting message of the "MMI-team".
It has been said that the phone number is the number of the Capitol building in Washington, DC (but not sure).
Siemens S15 Secret Menu's
Press * -> # -> 7 -> 4 -> 3 -> 6 -> 3 -> 6 -> 7 -> * -> 8 -> 3 ->
7 -> 8 -> # ,press clear key to clear screen and return to
stand-by mode
press Menu, it will show additional menu
Menu 3.3.4 Band selection,
Menu 3.3.4.1 Automatic band selection,
Menu 3.3.4.2 select GSM 900 only,
Menu 3.3.4.3 select GSM 1800 only,
Menu 10 Engineering,
Menu 10.1 MS info,
Menu 10.2 software detail,
Menu 10.2.1 software version,
Menu 10.2.2 EEPROM version,
Menu 10.3 Test/production details
Menu 10.3.1 Hardware deta
Menu 10.3.2 production deta
Menu 10.3.3 Service deta
Menu 10.3.4 Mechanical deta
Menu 10.1.1 MS info on, then on the screen show these, for example:
FCN RXL C1 C2
642 011+11+91 -> PAGE 1
CID DSC CB
11211 045 000 -> PAGE 2
BCC NCC TN
000 002 00 -> PAGE 3
RXf RXs RQf RQs
00 00 00 00 -> PAGE 4
ATa APa Hn Hf
001 000 05 00 -> PAGE 5
DTU DTD HP CI
+ ? - - -> PAGE 6
MM CC RR
IdNS Nul Idl -> PAGE 7
on Aug 30, 2009 | Nokia 9500 Communicator
How do i find a manual or the secret menu?
I don't think a monitor setting is causing Windows to not appear.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 24, 2014 | Likom Computers & Internet
Secret code for nokia to know the complaints
On the main screen type
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.)
Press and hold "0" on the main screen to open wap browser.
Important!
Try these codes at your own risk! We don't accept any complaints.
Some of these codes may not work.
Samsung Secret Codes
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Motorola Secret Codes
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Important!
Oct 16, 2011 | Nokia Lands Phones
ASA5510 Active/Standby Not Working
This is a old post, have you received and answer yet?
If not, make sure the internal interfaces are connected to one another and both have links. The ASA needs to have a "heartbeat" signal that passes between the 2 devices and this seems to be what's failing.
Dec 15, 2008 | Cisco ASA 5510 Firewall
Need power supply board for H21 LCD monitor
H-21 scan port Dark Screen, If you unplug the green light flashes 2 or 3 times ending any activity until completely unpluged and plugged in again. My other scan port works fine using 1st monitor cables. I've used both ports on the graphics card. It's definately the monitor power supply or other componant.
Any ideas?
Bill
Nov 12, 2008 | Scanport H21 21" LCD Display Monitor
I am attempting to secure my network through this router which at this time is open for the whole neighborhood to see
Here are the diffenent types of Security Settings possible with a wireless router: (how to set this depends on the brand of router)
Security Mode: You may choose from Disable, WEP, WPA-Personal, WPA2-Personal, WPA-Enterprise, WPA2-Enterprise, or RADIUS. All devices on your network must use the same security mode in order to communicate.
Capture(wlansec.wpapersharekey) WPA Personal:
Capture(helpwpa.phase8) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase9) WPA Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase10) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wpa2persharekey) WPA2 Personal:
Capture(helpwpa.phase11) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase12) WPA2 Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase13) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wparadius) WPA Enterprise:
Capture(helpwpa.phase14) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase15) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase16) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase17) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase18) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wpa2radius) WPA2 Enterprise:
Capture(helpwpa.phase19) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase20) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase21) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase22) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase23) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wep) WEP:
Capture(helpwpa.phase24) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase25) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase26) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase27) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Capture(wlansec.radius) RADIUS:
Capture(helpwpa.phase28) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase29) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase30) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase31) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase32) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase33) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase34) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Jul 03, 2008 | Computers & Internet
Code locking of siemens mobile phone
Siemens Mobile Secret Codes:
C25:
*#0606# shows you Secret Code, but only without SIM Card.
How to change PIN:
**04*old PIN*new PIN*new PIN#
How to check simlock status
*#0606# and then press left soft-key, you will see strange characters, then text ("brak blokad"). If you see for example 260-02, it means the phone is locked to Era GSM. In older models you can use *#06# and see the same information after clicking on left key (you will see IMEI and software version).
S4:
Monitor Mode - how to activate:
Press left soft-key, then 9 (SET UP) 8 (Phone Status). You will see IMEI number, then press left soft-key and in order 7684666 and red phone at the end (monitor mode has been activated). To read information from Monitor Mode - press left soft-key, then 5 (GSM SERVICE) and 6 (Monitor). Monitor mode turns off when you switch off the phone. You must activate it again if you want.
How to see date of software:
Press left soft-key, then 9 (SET UP) 8 (Phone status). You will see IMEI number, then press twice left soft-key, 98, left soft-key, 7684666, red phone (activates Monitor Mode), left soft-key, 56 (turns on Monitor Mode), left soft-key, 98, left soft-key, 7684666, hang up (red phone) &gt;abck to "normal" and then left soft-key, 56.
S6, S8:
If you add to phonebook under 'own phone number' +12022243121 with namez (for example MMI), then you will see something smile.gif
S10, E10:
In phonebook enter +12022243121 as your own phone no. You will see a picture with sun, two palms and greetings.
S15e:
Monitor Mode:
Code: *#7436267*8378# (*#SIEMENS*TEST#)
Hold red phone button until it code disapears.
Menu 3.3.4 Choose frequency.
Menu 3.3.4.1 Automaticaly.
Menu 3.3.4.2 Choose GSM-900
Menu 3.3.4.3 Choose GSM-1800
Menu 10.1 MS info
Menu 10.2 Soft date
Menu 10.2.1 Software version.
Menu 10.2.2 EEProm version.
Menu 10.3 Tst and product info.
Menu 10.3.1 Handware data.
Menu 10.3.2 Date of manufacture
Menu 10.3.3 Service date
Menu 10.3.4 Date of repair.
S25:
Enhanced Full Rate
*#3370# turns on
#3370# turns off
Haft Rate Mode
*#4720# turns on
#4720# turns off.
Languages:
*#0000#+green phone - choose automaticaly
*#0001#+green phone - English
*#0030#+green phone - Greek
*#0031#+green phone - Netherlands
*#0032#+green phone - French
*#0034#+green phone - Spanish
*#0039#+green phone - Italian
*#0049#+green phone - German
*#0090#+green phone - Turkish
How to change PIN2?
**04*old PIN2*new PIN2*new PIN2#
What is my software version?
Menu 8-8-2 press left-softkey when you see IMEI number, or *#06# and then green phone button and then press left soft-key.
How to extend battery life:
IrDA - turn on only when you need.
Turn off automatic network search (6-3)Turn off Vibration alarm.
S25, M35, S35, C35
Nov 29, 2007 | Nokia 1100
Dell 1704FPTt 17" TFT LCD Flat Panel Monitor Logo
278 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
