Question about Astec (AA11890) (AA21890) 700-Watt Power Supply
LOOKING FOR ASTEC MODEL AA16510 POWER SUPPLY
5 Suggested Answers
SOURCE: which wire is the 'ON-PS' switch for the Astec
I found out that the AT supply SA145-3435 does not have a switch wire like an ATX supply. I have a SA145-3435 my self. To get it to work it must have a +5 volt load (BLACK and RED) and a +12 volt load (BLACK and YELLOW). If it does not have both of these loads it will power down after a 2 second delay when you plug it up. I used 2 small 12 volt bulbs. One for the 12 volt line and one for the 5 volt line. The type of blub I used was a #94 I got from the auto parts store.
Posted on Oct 18, 2009
  • 1738 Answers
SOURCE: I am looking for a manual and troubleshooting
Look it up on the internet you should be able to find one. Try the www.astec.com website first.
Posted on Nov 20, 2009
  • 87 Answers
SOURCE: my astec atx202-3515 power supply
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
Posted on Mar 09, 2010
MNfisherman
  • 11896 Answers
SOURCE: I need a data for the Astec SA302-3515 300-Watt
Everything you need to know can be found here:
http://www.atxpowersupplies.com/300-watt-power-supply-fsp-atx-300-gu.php
(just copy and past the above link in your internet address bar in a new tab)
Posted on Mar 31, 2010
ASTEC 63DV ALARM INSTALLATION MANUAL
Hi.
Would anybody have an Installation Manual for Astec alarm panel.
Feb 11, 2013 | Vehicle Parts & Accessories
Looking for schematics of ATX200-3516 ASTEC power supply. When i plug in a dc motor i have a peak of current firstly more than 6 Amps (6 amps is max rating at 12 Volts in such supply). So It shut the...
If your power supply is rated 6 AMPS and your motor is rated 14 amps peek, then when that motor starts it will draw the 14 AMPS, That will trip the power supply right then and there. After it runs a few seconds the AMPS will drop about ½ that, but still 7 AMPS is more then the power supply is rated, so you will need a different power supply.
Aug 08, 2011 | Astec (ATX200-3516) (ATX2003516) Power...
Ref ASTEC power supply from old computer model SA 147-3505 I can pick up the logic 5 volts but not the +12 volts and -12 volts .FAN not energised so I guess there needs to be an elec link via the computer...
You can jumper on an ATX power supply by using a wire to connect pin 4 (green wire) to any of the grounds on the 20 pin ATX connector. The grounds are normally a black wire. You will need to put some sort of load on the power supply such as a hard drive to keep it running.
Feb 25, 2011 | Dell PWR,SUPPLY,145 WATTS,ASTEC SA150-3411...
I am looking for a product data sheet and/or manual for the Astec SS500-3405 power supply. Might you be able to assist? Thanks,Tony.
The three I have inspected, all of them failed due to the vent. It breaks down and makes the power supply to stop.
Jan 04, 2011 | Astec Computers & Internet
Dear Sir, I have astec model AA23160 power supply input Ac 100-240 5A max output Dc +5v 23A, +12v 22A max it does not give output the LED give yellow when it is ON. the two cooling fans were also not...
Hi! l have have the same problem whit the Asctec model AA23160 power supply.But l need to know how many time your power supply worked: How many time do you use it?
Thank's!
Aug 13, 2010 | Astec 300w AT Power supply 190170-01...
My astec atx202-3515 power supply blew up. I accidently changed the watt to 115. It was 230 watts before. Will the power supply still work oe will I need to purchase a new one?
Mar 09, 2010 | Astec (ATX202-3555) (ATX2023555) 200-Watt...
I need an ASTEC power supply model SA147-3506 for IBM P-2 computer, Can anybody help me??!!
145 Watt power supply with the old style AT motherboard power cable connectors. (2 Each)
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
I just put Astec SA147-3506 in my browser search bar, and came up with a number of search hits. Prices ranged from $50 to $170!
And it's a 145 Watt power supply! Astec is a cheap quality power supply manufacturer, to boot!
You know, there is a way to use a newer reliable power supply, and the AT power supply motherboard connectors, off of the power supply you have.
It's not for the squeamish, but can be done.
The power wires are removed from the ATX power supply motherboard cable connector, of the new power supply, and inserted into the AT power supply connectors.
(ATX 12V power supply is the newer one. AT power wires removed from the P8, and P9 connectors of your old power supply)
Interested?
Jan 20, 2010 | Computers & Internet
Hello, i have a Astec 110s central vac that shut down today.
That means that either the motor or the relay is bad.
Dec 04, 2009 | Vacuums
I am looking for a manual and troubleshooting manual for a astec 73-180-0029 POWER SUPPLY
Nov 19, 2009 | Astec Computers & Internet
Astec (AA11890) (AA21890) 700-Watt Power Supply Logo
208 people viewed this question
Top Astec Computers & Internet Experts
David Payne
David Payne
Are you an Astec Computer and Internet Expert? Answer questions, earn points and help others
