Question about Pentax Cameras
My Pentax P50 will not fire the shutter even though with new batteries. The metering system etc seem fine
  • 15 Answers
SOURCE: Bronica SQ-Ai shutter problem
There could be a number of issues with this problem. Make sure the contacts at the rear of the lens and those on the body that connect with those on the lens are clean and straight. If so, the problem may be in the shutter within the lens. There is a magnet inside the shutter that sometimes becomes contaminated and fails to hold the shutter blades open for the selected shutter speed. The face of the magnet may need to be cleaned. There are also timing switches that sometimes go bad or need adjusting. These internal problems need to be taken care of by a competent technician since the lens needs to be completely disassembled. I have also seen these shutters go bad and need to be replaced. Let's hope that's not the problem because it will be difficult to get a new shutter for the lens--but not imposible. God luck.
Posted on May 01, 2007
  • 619 Answers
SOURCE: Shutter release
Hi , to release the shutter open the lense and push shutter button , rotate the camera mode to auto or manual release shutter.donnot set on bulb or lower speed can cause stuck camera miror and stter curtain, or blade.
Posted on Feb 28, 2008
cammedic
  • 667 Answers
SOURCE: sears ks super camera.
You'll have to remove the bottom cover. Either the mirror box or the shutter are stuck. re-cocking it is possible by moving the wind stop clear of the bottom portion of the film advance shaft.
Posted on Aug 20, 2008
SOURCE: shutter speed
My suggestion is an obvious one, though I messed up a job not figuring this out til afterwards! The battery. If the battery is weak or cold there will not be enough voltage to keep the magnet active and holding the shutter open for the correct amount of time. (This was confirmed by Johnsons Photopia on the phone). This will mean you may have set a slow shutter speed of say 8s but the actual speed you get will be the default manual speed of around 1/400s, which is the speed the shutter fires at when you have no battery. This will result in underexposure and the shutter sounding as if it is not holding open long enough as you describe.
If you are getting overexposure then I would expect the shutter to be open longer than needed for some reason, which would be another problem.
Posted on Oct 16, 2008
localwonder
  • 6784 Answers
SOURCE: battteries depleted messageon Pentax Espio E40, even though have tried brand new batteries.
HI. this seems to be a battery scanning fault in the programming. try to reset the board by pulling the battery and removing all power of 30 minutes. completely drain all power from this unit for 30 minutes. if this message continues after you have rest the programming, this will confirm a serious fault within the internal program. you will have to send this device back to a pentax repair terminal for reprogramming.
Posted on May 22, 2009
Hi, have pentax k100 d, like new taken very good care of. Stored with batteries removed. Now all I get are low sound clicks firing only when button is pressed. Went into menu and opened shutter and turned...
Sounds like your shutter is stuck. Given that the camera is only worth about $100 -- or even less -- it's probably not worth sending in for repair. You can buy a good used "upgrade" like the K200 or even the K-50 for about what a shutter replacement would cost.
Mar 23, 2018 | Pentax Cameras
Nikon F3's light meter always underexposed
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Mar 06, 2010 | Nikon F3/T 35mm SLR Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
My shutter wont fire? I have new batterys good film and everything it just wont work the light meeter works though?
If you can wind the film there is a problem with the shutter release. Take it to the shop to be checked and/or repaired. There's practically nothing you can do yourself (unless you're a camera mechanic).
Nov 17, 2009 | Pentax ME Super 35mm SLR Camera
Diagnostic says i have a p50 error on 94 voyager
You need to have your charging system alternator, connections etc, checked if battery keeps dying. Are you sure it code P50 your getting?
Feb 24, 2009 | 1994 Plymouth Voyager
Pentax ME Super Seems to alway be in bulb mode.
Hello igby Slocumb,   As I recall, this was Pentax's way of mating electronics with mechanical cameras and the success rate was quite good. The only problem with the Pentax Super Program was the rather complex electronic circuit board. Your canera could have bad batteries, or batteries with too low amperage therefore no electronic shutter, have a short in the wiring, etc. You would need to do a shutter circuit check using a benchtop AC/DC power supply to exclude the batteries. Wow - really expensive and time-consuming = complete stripdown and repair. The camera is over approximately 30 years old making it a classic. It is no longer in production meaning parts need to be cannabalized from another old non-working Pentax Super Program. The cost of repair would exceed the value of the camera. Look for another good used model or move on to a Pentax DSLR (digital SLR) camera as your tool. Sorry I couldn't give you a better answer on how to fix your problem.
Jul 03, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME slr (old hand film wind )
the film might not have been catching onto the wheel it has happend to me befor
Oct 05, 2007 | Pentax ME Super 35mm SLR Camera
Light meter failure and shutter button sticking
Set your camera to B and release the shutter ( camera will work in this mode without batteries ) if you can wind ok and release shutter fine then all you need is new batteries. If however your camera is not working when set to B then it is either the shutter or the transport mechanism that need looking at. From experience ( have repaired 100s of Me-supers ) it is likely that your shutter needs attention : rubber components ( and foam rubber ) inside the shutter ( and the mirror box locking mechanism especially ) have perished and need replacing.
Sep 21, 2007 | Pentax ME Super 35mm SLR Camera
IstD shutter release problem
I've had similar problems with my Pentax Super-A on an intermittent basis. If you haven't replaced the batteries I suggest you try that first. Not sure why, but that has sorted my problem out quite a few times (even when the existing batteries still have a fair amount of juice left in them).
Sep 08, 2005 | Pentax *ist D Digital Camera
Cameras Logo
85 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
