Question about Samsung SyncMaster 216BW Monitor
Need to turn off and on 9 times before get solid pictre
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 14, 2010
  • 732 Answers
Rbrown6377, Monitor will need you or lcd technician to repair the unit's "switch-mode-power-supply/ccfl inverter supply". Cost of DIY repair might be as low as $6 to $10. Just do some reading of my and other fixya tech's profiles for more info. 12fixlouie
Posted on May 12, 2010
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
The problem is a failed, welded joint. This joint is where the short bracket holding the pulley at the bottom of the U-shaped arms used for doing the vertical and horizontal chest presses, for example,...
Greetings to the people in Sports Art America Land You Need to call Body Solid. The frame welds have a LIFE TIME warranty, these people know their products and they give great customer Service I Know I'm one of their dealers!!!
TECHNICAL SUPPORT
Available M-F 9:00am to 5:00pm CST
Toll Free - 800-556-3113
Fax - 708-427-3598
Aug 11, 2010 | Body Solid Body-Solid EXM 1500 Home Gym
HAVE REPLACED BOTH THE PCU & THE TONER IN MY LEXMARK E250DN PRINTER BUT STILL KEEP GETTING ERROR MSG TO REPLACE PCU IT HAS REACHED THE END OF IT'S LIFE
you need to reset the counter. the new pcu should have come with instructions to do this. 1. Turn off the printer. 2. Open the front cover. 3. Press and hold the Continue button (Big silver button with Diamond shape symbol) and turn the printer on. 4. Hold the button down until the last light (error light) is on solid, release the button and close the front cover. 5. When the cover is closed, all the top 3 lights should be on solid. 6. Press the cancel button (triangle symbol) 4 times very slowly until you see the toner low light (second light from top) on solid. 7. Press the continue button and wait until you see the light sequence. 8. Press the cancel button and wait until you see the light sequence. 9. Finally power off the printer and power it back on to exit the configuration mode.
Jun 16, 2009 | Lexmark E250dn Laser Printer
Help! My TV is turning red
It may be a problem in the picture tube of your TV set. It may be because of various problems such as you might have wiped your TV screen with a cloth or some thing very harshly or your TV is in a position that it receives direct air from an AC or a room cooler.
If u have a plasma TV which do not have any picture tube then u may have pressed the screen hardly.
The solution for a TV with a picture tube is that you may need 2 change your pictr tube or call an expert from the company from where u purchased you TV.
If its a TV with a LCD screen then u may need to adjust the contrast to a lower pictr quality or u may need to refill the liquid inside the screen.
Sep 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Lines in every pictre ,
Many compact digitals (of all brands) use a Sony sensor and Sony had a bad batch go through and the sensor's contacts are failing.  If you are getting images corrupted with lines, bad/weird colour or severe noisy hash, you may well have a dud sensor.  Check the canon web site for a list of effected cameras and/or contact Canon service.
Canon is replacing effected sensors free of charge regardless of warranty status.
Jan 31, 2008 | Canon PowerShot S2 IS Digital Camera
Samsung SyncMaster 216BW Monitor Logo
137 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
