Question about Western Digital 80GB Passport 2.5" USB Drive 80 GB Hard Drive
My westron digital 500 passport is not detected by my system.
My wd hard is not detected, at the place all pen drives and other hard disks are working fine...
can please help me, i have stored all my data in this hard disk only...
  • 1,606 Answers
The first thing you want to do is make sure that the drive is not being detected on other usb ports on your computer and if not then you want to try it on someone elses computer to make sure the problem is in the drive.
I will assume that the drive isn't being detected on anything. On usb drives there is a usb interface and a normal hard drive inside the case. Unless you have dropped it a few times the problem will be in the usb section. There really is nothing you can fix in the usb section. The good part is that the hard drive and your data is most likely just fine.
Luckily you can get usb drive enclosures for as cheap as $15 (and up). This means it is worth taking your drive out and putting it in the new enclosure. You may need to buy a cable adapter which just lets the real small hard drives be able to plug onto the normal sized ones thats about $5. The problem with doing this is that most usb enclosures use an external power plug and are not powered off of the usb port.
This will enable you to get your data off and reuse the drive but it may not be as convienient as it was due to the power adapter.
If you are comfortable with doing simple computer repairs then this is about the same as putting in a new hard drive. If not then any computer store should be able to do it for you for a reasonable fee as it is just labor.
This won't fix your drive but it will give you your data back which is the important part.
Posted on May 12, 2010
My WD my passport not working
maybe the cable plug of the WD my passport is broken
Apr 18, 2013 | Western Digital My Passport Essential...
WD external HDD my passport 500 Gb . It's not correctly installed into my PC - PC can't find driver. System Windows XP
Maybe it's a power issue. Try a shorter usb cord or try a different usb port. If you are using an usb hub, try to connect the hard disk straight to the pc.
Feb 28, 2011 | Western Digital My Passport Essential SE...
I purchased my wd hdd (500 GB) storage device from CANADA It was fell down from table while working ......... so now it is not working ....... though it showing that some removable device is connected...
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Note that W.D. has a "Customer Loyalty" program; buy a new disk-drive from the W.D. web-site, at a good discount. Or, search online for a professional "data recovery service". They will repair your disk-drive just long-enough to copy your files to a brand-new disk-drive.
Oct 28, 2010 | Western Digital WD Passport 250GB Portable...
My Western Digital Passport 80GB Hard Drive is no longer detected when I plug it in. The power light is on, the drive is running but it is not detected on either of my computers running Windows...
Any external disk-drive as small as 80GB is probably "out-of-warranty" -- it's likely that the disk-drive inside the enclosure has "died".
You have two options, not mutually exclusive:
* exercise the Western Digital "Customer Loyalty" program -- find the serial-number of your Passport, and access WD's web-site to buy a new Passport, citing the old serial-number to qualify for a significant discount on your purchase;
* open the enclosure, disconnect the disk-drive from the USB-to-disk-drive adapter, buy a new, compatible, disk-drive, and connect it to the USB-to-disk-drive adapter, to "frankenstein" it, creating a "new" external storage-device.
Oct 24, 2010 | Western Digital Passport WDXML800UE...
My computer is not recognizing my Western Digital passport elite what do I do?
Have to check it in the Device Manager that the new device have been detected or not. It may happen that when the external HDD connects to the computer for the first time computer cannot detect it as it is not properly formatted in proper file-system. Open Computer Management and click on Disk Management and format the device correctly to operate.
Jun 21, 2010 | Western Digital WD Passport 250GB Portable...
Not detected in xp
hi
go to WD site and get drivers for XP downlod and run that then try hopw fully it will work
May 25, 2010 | Western Digital My Passport Essential...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
I have new wd external hdd 250 gb, its not detecting on my desktop.
Is the drive formatted? Did you get an install disk supplied with it? If so try running it.
Check your system BIOS and see if the drive is being detected there. Also you can check the Device Manager in Windows to see if there any issues with the drive.
Sep 12, 2009 | Western Digital WD Passport 250GB Portable...
My WD 250GB passport portable hard drive is not recognized
If your system detects the connected device that is a good start. Was the drive formatted for another operating system? Certainly try the drive on another system and/or another drive on your system.
Aug 26, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital 80GB Passport 2.5" USB Drive 80 GB Hard Drive Logo
88 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
