Question about Kenmore 20172 Top Load Washer
My washer machine wont spin but the motor is working making aloud noise
  • oldguy5 May 12, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. WILL IT DRAIN??? CAN YOU HEAR / SMELL ANYTHING UNUSUAL??? WILL IT AGITATE WELL???
  • 5,911 Answers
The most common cause of the symptoms you describe is a broken motor coupling. No agitation, or spinning, associated with a grinding noise are the usual symptoms. The washer will still have the ability to drain, however.
The following link explains how to access the coupler and replace it, if necessary:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is usually sold as part of their in-store inventory. The average cost of a motor coupling is about $15.
If you have any questions, or if the symptoms I describe do not match the problem you are having, please post back and let me know. I hope this helps you.
Posted on May 12, 2010
Won't spin makes aloud humming noise
if its new machine,,might problem with hole sensor,,,
Feb 16, 2014 | LG WM-2077C Front Load Washer
Washer wont spin but makes loud noise
-could be a belt failure or some washmachines are directly coupled to the motor. - the coupling or belts are easliy replaced and visible if failed
Jan 12, 2012 | Washing Machines
It making aloud noise when spinning dry
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My front loading washer makes aloud noise and shakes terrible when it spins at mediun or high speed. model ifw7200tw
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Nov 26, 2010 | Washing Machines
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
My washer makes aloud noise when on the spin cycle. HELP I Started a load of laundry and it washed fine until the spin cycle. It started making a terrible noise.
sounds like the bearings have worn out at the back,to check this open door and with your hand lift chrome inner drum up and down if you feel like a knocking noise then its bearings,
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Motor wont spin
whats makes the noise on spin if motor not turning at all.. i kinda confused... I Would check lid switch and see if maybe that might be the problem.. havnt had a lot of experince with hover but most washers have lid switchs to prevent spinning when lida opened
Sep 02, 2007 | Hoover AAA140 Front Load Washer
Kenmore 20172 Top Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
