Question about Kenmore Vacuums
How to wind cord onto spring loaded retractable cord reel for a Kenmore canister vacuum. There is a metal 'U' shaped, spring loaded, piece that fits over the outer aspect of the wheel. If cord needs to get wound on under this metal band I can't figure it out and the band is like factory sealed onto the wheel. Also. I don't know which direction to feed the cord onto the wheel
  • 15,935 Answers
What is the exact model # please?
Thanks!!
Posted on May 12, 2010
  • 2 more comments
  • laua744 May 12, 2010
    Kenmore canister 4.5 power mate-Model116-2645086 (There is no manual available, I have already checked)
    I'm here. Sorry I wandered off after the first contact. I didn't think I would get an immediate response
    Since I am wanting to get this repair done today I think I'll go to the next expert. UNLESS YOU ARE THERE. I will wait 10 more minutes before I ask for a new expert.
    If I ask for a new expert it means I am dissatisfied with your answer. I have to leave for a while but will leave this web page open. I will be back in a few hours and if you have not responded I will look else where.
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Oct 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Power cord broken inside reel
the reel doesn't come apart, its a replaceable item. the only place that you can get another one is through sears.
Jul 19, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
May 11, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Power cord reel problem with a kenmore canister vacuum whisperti
Pull the cord all the way out and see if it's contaminated with anything sticky. Also check the guide rollers that the cord rides in and see if they are rolling smoothly and without resistance - they may also need cleaning. If so, clean it off and try again.
If not, it may be the spring reel itself in which case you may need to replace it.
Apr 30, 2009 | Kenmore Progressive 20912 Bagged Canister...
Cord retraction help
if you can open it up extend the cord and wrap it around the spool.make sure its clean.spray a little wd40 on the shaft of the pully so it moves freely
Apr 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
S3765
Returned the sweeper to Costco for a full refund and bought another.
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
Yanked the cord out of the vacuum
Wasn't able to find any diagrams either, but there should be some screws to take out, and the top and bottom should separate. Don't let the cord reel spring unwind if it hasn't already done so. If it hasn't, one half of the reel should come aprt so you can re-attach the cord. then put the reel back together and let it wind the cord on the reel. If the spring is unwound and/or the reel wasn't made to come apart, then you will have to replace the cord reel asm.
Feb 28, 2008 | Bosch BSG71360UC Bagged Canister Vacuum
Won't Turn On
Mine was a simple fix. Hope yours is too.
You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
http://www.sannerud.com/house/miele.html
Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
Now, here is the trickiest part - not really that tricky if you are good with your hands.
First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
Dec 23, 2007 | Miele S514 Solaris Turbo Plus Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
95 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
