Question about Fitnex T60 Commercial Treadmill W Heart Rate Control
WHAT ARE THE NUMBERS THAT APPEAR IN THE SCREEN @ 12'OCLOCK
WHAT ARE THE NUMBERS THAT APPEAR IN THE SCREEN LOCATED AT 12'OCLOCK POSTION ON TOP OF DASHBOARD. IT STARTS WITH 0 AND GOES UP AS YOU CONTINUE YOUR EXERCISE. I REACHED FIVE ONE TIME. DON'T KNOW WHAT THAT MEANS. THIS UNIT IS AT OUR APT COMPLEX AND THEY DO NOT HAVE A MANUAL.
THANK YOU
CHUCK GRAD
    President:
  • Fitnex Master
  • 832 Answers
I am assuming that its where the display the program image ( Interval random hills etc) If they cannot find the manual here is the companies info so you may get contact them :
Fitness Master Inc.11419 Mathis #200
Dallas, Texas 75234
TEL: 214.350.8884
FAX: 214.350.8876
TOLL FREE: 1.866.4FITNEX
EMAIL: info@fitnexonline.com
Posted on May 14, 2010
How do you set a Elgin Sportsman GF010-007 watch
Not familiar with this watch, but try this other FixYa answer :-
rfhutchinson
SOURCE:Elgin Sportsman How do I set the time?
Simple..there are 4 buttons on this watch. Right?...All four buttons push in...no kidding....HOWEVER the button at the five(5) oclock postion...PULLS OUT...this is the key..because this only button, pulls out, i
The digital display starts to flash....just experiment with pushing any button, BUT the five oclock and you should be able
To figure it out. After its set, then push the five oclock back to its origanal postiton...
Nov 20, 2017 | Elgin Watches
Tracer wont start
What else? You didn't say what year tracer, but yes, you are right: both the crank and cam sprockets must be at 12 position.
Here is a link:http://www.2carpros.com/diagrams/mercury/tracer
If timing is correct, check for spark on all 4 plug wires, or at least a couple of them. If timing and spark are good, you may need to test fuel pressure. Multiport injection pressures are high, up around 40 psi or more.
Sep 10, 2015 | Cars & Trucks
How can I factory reset my Toshiba Satellite laptop without a disc?
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Feb 14, 2012 | Toshiba Satellite 2405-S201 Notebook
I REPLACED WASHERS UNDER VALVE HANDLE AND NOT SURE THE CORRECT WAY TO LINE UP HANDLE AND VALVE IN RELATION TO THE POSITIONS OR FILTER. iT IS A HAYWAR S-180T
with Vavle apart the ring the handle attached to when assembled has a V in it this V goes at 12 oclock and the top plate slips over the diameter sticking up with thee words FILTER at 12 oclock BTW the V im talking about could be a curved rectangle too..
Jun 03, 2011 | Hayward SAND FILTER, PRO SERIES
Jan 06, 2010 | Elgin Watches
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
Rover 220 tdi
4cyl there are two marks on the came gear and the word top on it align the marks even with the cylinder head with the word top --at the top the crak gear has a mark by the key way put this at 12 oclock if you look there is a mark on the block align it with it on the back of the block thres is a 12 mm bolt remove it and slide a 8 mm bolt in the hole there is a mark on the bac balancer shft put in around the 4 oclock postion the frt balncer shafr has a mark you will have to keep it align your self keep the mark around the 8 to 9 oclock if you look there is a mark on the balance shaft cover if you havent removed the belt put the came in place and you will see what im talking about the marks
Oct 06, 2008 | 1999 Honda Accord
Fitnex T60 Commercial Treadmill W Heart Rate Control Logo
61 people viewed this question
Top Fitnex Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Fitnex Exercise and Fitnes Expert? Answer questions, earn points and help others
