Question about Craftsman 18" Chain Saw Replacement Bar 36638 3619
Chain jumps off guide - Craftsman 18" Chain Saw Replacement Bar 36638 3619
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain. Lay the chain out on a bench or table--inspect it for sideways bent or broken links. Check the chain drive teeth for damage as well as the sprocket drive teeth. Inspect the bar chain groove for damage or sideways bending, also the tip sprocket for free turning. Start the engine after cleaning the bar mounting area on the side of the engine, it should ooze out oil after running for a short time. Clean the bar drive-end oil passages which run out to the chain groove. Clean the entire chain groove. If all checks ok, re-assemble the bar and chain, but leave the mounting fasteners finger tight. Tighten the chain until it pulls up to the bar bottom, but not so tight that you can't move the chain by hand. Tighten the bar fasteners firmly and recheck the chain tension. Start the engine and run the bar tip near some cardboard at speed for a few moments--it should throw off a thin line of oil. Hope this helps!
Posted on Jul 23, 2010
Why does my timing chain keep jumping time.i have set the timing three times
If it is a chain. Check the shear pin/moon key on the crank shaft.
Nov 08, 2015 | Cars & Trucks
What can cause the timing chain to jump time on an 05 ford explorer
The 4.0l sohc v6 is notorious for breaking the plastic chain guides. You will need t remove the engine to repair it properly and there are lots of special tools required to properly time the vehicle. There are actually 4 timing chains and I suggest replacing all 4 and their respective guides and tensioners.
Jul 27, 2015 | Cars & Trucks
Is there a simple way to see if a 2004 jeep 4.0 jumped timing without stripping to the timing chain?
You have a chain in it, not a belt. It hasn't jumped a tooth or two. Guides could be worn. It would throw a code. But it wouldn't jump. Whta's the problem?
Dec 03, 2014 | Cars & Trucks
Check timing chain on a 94 corcica 3.1 L .May have jumped time.
Take all the spark plugs out and bring #1 piston up to TDC. Look at the timing mark on the pulley. If they don't line up, then timing has jumped. If that's the case replace the chain and both the cam and crank gears.
Sep 17, 2014 | 1994 Toyota Corolla
Brand new RYOBI RCS3535CA 35cc Petrol Chainsaw. Chain came off the guide after only cutting a couple of branches. Refitted the chain but chain doesn't run. The chain is on the drive sprocket. What could be...
With chainsaws once you refit teh chain to the sprocket (it runs one way only) and the guides are sitting in the groove in the bar. The bar needs to be pushed so there is very little flex in the chain and then the nuts that hold the bar on should be tightened. If the chain is loose it will not get driven properly and it will jump off the bar. Also if oil is not lubricating the chain it will heat up quickly, stretch and jump off the bar. If in doubt - take it to your local chainsaw mechanic for checking and a demonstration.
Feb 08, 2011 | Garden
Tensionor guide broke can it be fixed
Timing chain tensioner guide on the 2.7? Yeah you can fix it. Did the chain jump? Does it run still.
Jul 30, 2010 | 2002 Dodge Intrepid
My timing chain is ratteling
If it's the DOHC engine, I would change it ASAP. There are chain guides and a chain tensioner, if those wear too much, it could jump time and then you'll have big problems.e06b139.jpg
May 14, 2010 | Saturn SL2 Cars & Trucks
Looking for Timing Chain Guide
Check with Auto Zone if no...see the Dealer but also check the camshaft gear sprocket...if its composite you may need to replace it as well...this also causes chains to rattle and jump.
May 06, 2010 | 1998 Ford Explorer
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
Craftsman 18" Chain Saw Replacement Bar 36638 3619 Logo
118 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
