Question about Lenovo 3000 J115 (7387-A11) Desktop Computer Bundle With AMD Athlon 64 X2 Processor 3800+ With Enhan... (W101787)
Periods of monitor image flutter. What is cause?
Two problems. 1. On bootup, monitor image in constant flutter. Periods of monitor image flutter lasting ten minuets to three hours.
What is cause? How to fix?
2. Have several desktop links to web sites. When click on most of them IE does not respond. There is one to which IE does respond.
3. Will not go into Hibernate or Standby. Gives message 'device driver for the 'Tterminal Server Keyboard Driver device is preventing machine entering hibernation. Close all applications, try again. If problem persists, you may need to update this driver'.
OS is XP Home Lenovo 3000J115, model #738726u
    Guru:
  • 551 Answers
1. check the monitor. use other monitor. if still occur check video card. use other video card.
2. try upgrading the memory module. or have it replace.
3. scan for virus infection.
Posted on May 13, 2010
Emachine 1200-06 desktop computer plug in power supply cord computer fan starts up and hard drive sounds like its running power light on but cannot turn off and will not bootup or monitor will not come on...
Mike, for the problem you have this is the wrong forum. Way too complex for this site. Go here: www.suggest-a-fix.com, register and post your problem in the Hardware section. And, please, use periods; your post is very confusing without proper punctuation.
Aug 13, 2013 | Washing Machines
Haze
Rather hard to properly diagnose this one off such a short description, but...
1/ Bulb OK, not over hours or otherwise damaged?
2/ Is it constant for all images, just a general coloured haze, not a strange "shadow", "ghost" or "fringe" that alters depending on what you display?
3/ Lens nice and clean?
4/ Surface you're projecting it onto also clean and at least nominally white?
5/ Input cables all fine at both ends and work correctly with other output devices (TV and/or computer monitor)?
6/ Haze still in place with different cables and input devices?
7/ Does the projector regularly show the same static image for extended periods?
The VT460s were buggers for suffering from internal LCD and filter glass issues if allowed to overheat, and with image burn-in, especially if fitted with unusual lenses (e.g. extreme short-throw); I've had to do internal cut-and-swap surgery on a few of them before, with donor image elements from projectors that died due to other problems. I can't say the one VT470 has shown any sign of similar, but the two VT480s are worse if anything. So it's entirely possible that we just got the one good VT470 out of the whole production run. As intimated by the above, it could be anything out of a failing bulb, dirty lens (or internal image element) glass, image burn-in, LCD/filter damage from overheating (and mind that being turned on showing a "blank" screen for ages can cause a similar effect, as all of the bulb's 200 watts of light energy is then being completely absorbed by three thumbnail-sized pieces of liquid crystal... the bulb doesn't turn off unless the projector is shut down completely!), problems with internal circuitry, dodgy cables, unsuitable projection surfaces, or problems with the devices feeding images to it. It really is a minefield until it can be narrowed down.
May 11, 2012 | NEC VT470 Multimedia Projector
Monitor flikkering .i will check the VGA cable and power cable both are properly connected but the monitor is flikkering .what i do
Answer Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Dec 14, 2010 | Acer AL1511 15" LCD Monitor
Does leaving pfictures constantly showing on tour computer harm the computer?
Not if it is a TFT/LCD flat screen. They do not suffer from screen burn. Older CRT and plasma screens do suffer from screen burn from stationary images on screen for long periods of time.
So you should be ok if it is a TFT display
Sep 04, 2010 | Computers & Internet
My screen flutters constantly. Will stop if you
Inverter failing or loose wires from motherboard to screen. Tried connecting it to an extarnal monitor?
Feb 09, 2010 | HP Pavillion DV8125NR (EP410UA) PC...
Screen flickers with lines but when i move the screen it stops
A nearby device can cause stray magnetic fields that will cause the display to be affected. A problem inside the monitor will cause the display to have problems. If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
ERNZ
Feb 03, 2010 | Toshiba Satellite A105-S4004 Notebook
W2753v screen flicker - refresh
Hi
What causes monitor screen to flicker?
Answer
Answer
Jan 29, 2010 | Computers & Internet
Display is all garbled on bootup, cannot read image.
Test if it's your graphics chip by connecting a desktop monitor to the laptops serial port,reboot the laptop, and look to see if same thing happens on the external monitor.. If it does, then you have a failing gpu/graphics chip.
Nov 16, 2009 | Lenovo ThinkPad T40p (odep9-s2759776) PC...
Monitor turns pink quite frequently
i think problem is the vga cable of monitor try to remove the cable of your monitor attache to pc or try to reconnect the vga cable
May 21, 2009 | eMachines E17T4W 17" Monitor
Lenovo 3000 J115 (7387-A11) Desktop Computer Bundle With AMD Athlon 64 X2 Processor 3800+ With Enhan... (W101787) Logo
169 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
