My kenmore elite calypso has a code of ld - Washing Machines
    Problem Solver:
  • 17 Answers
Most likely your pump is clogged. Google my post on www.bobvila.com to see how to get to pump and check/replace it if necessary. Hope this helps.
Tom
Posted on May 20, 2010
  • 3,230 Answers
Well error Ld means - Long drain - The Ld error code indicates a long drain. It is displayed when water level does not change while the drain pump is running. Anyway you can please check out the following steps -
Is the drain hose kinked or clogged?
Check the drain pump for clogs. Is it running?
Is the drain hose height greater than 95 inches?
Is the pressure switch hose connection from the tub to the machine control board pinched or plugged?
Do you see excessive suds in the basket? Are you using high efficiency (HE) detergent?
You can try to reset your washer by Pressing STOP/CANCEL. Please check out all the above steps, post comments if further you have the same problem.......
Good Luck!!
Thanks
Posted on May 12, 2010
4 Suggested Answers
  • 113 Answers
SOURCE: Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Posted on Dec 16, 2008
  • 49 Answers
SOURCE: my kenmore elite calypso keeps beeping Fl what
FL (flood condition) also can be an indicator of a bad pump. The washer tries to drain and cannot because the pump has failed or is jammed with debris.
You can run a complete washer diagnostic procedure to see if you can isolate the fault by doing the following. I recommend you make sure the room is quiet so you can hear the pump motor running when expected, as well as the main drive that nutates and spins.
Perform a "key dance" to put the washer in the diagnostic mode by pressing the Prewash Options button, Wash Time, Prewash Options, Wash Time - each 2 times in rapid succession within 5 seconds total. The display will change to 99 and begin counting down (in seconds) as it runs the following tests. Listen for the pump motor to actually run and not just "hum", indicating a jam or burnout.
Display 99-81, Nutate & fill
Display 80-61, Nutate & recirculate
Display 60-41, Nutate, Fill & drain **
Display 40-21, Nutate, Fill & drain **
Display 20-0, Spin & drain **
You can cancel the test in progress at any time by pressing the Stop/Cancel button.
**during these phases the pump will run forwards and backwards (recirculate & drain). If you do not hear water pumping inside the washer or draining out the drain, your pump is likely bad and needs to be replaced.
The old style pump was a two-part assembly and the re-engineered part # mentioned above is a single piece that solves the impeller failure problem the original pumps were prone to have.
www.pcappliancerepair.com sells replacement pump part # 285990 for this washer and they are a reliable supplier with a good value. You can purchase a lifetime warranty on the pump from them for an extra fee.
Unfortunately there is not enough room in this text box to post the pump removal & replacement procedure but you can get your local handyman to do the work for you if you are not inclined, as I was, to drain the washer and turn it on its side to figure out how to replace the pump.
The other problem is that once you start getting a pump failure you need to look at the root cause. If the pump was ruined by draw strings or debris being sucked into the pump impeller, it is time to replace the top wash plate assembly (the plastic plate inside the washer that the clothes sit on).
There is a rubber seal on the outside edge of this plate which wears out over time and rotates upward, opening a bigger gap between the plate and the stainless steel drum which lets draw strings and other things get sucked all the way down into the pump. The upper wash plate & seal is a single unit and the seal itself cannot be replaced as it is molded into the plastic piece. Order this from Sears to insure a more recent 'cure date' on the rubber seal from the manufacturer, rather than 3rd party suppliers who might stock the part for longer periods and have old rubber seals past their cure date. The wash plate should be replaced about every other year.
Posted on Oct 03, 2009
tbirdfan1
  • 3051 Answers
SOURCE: What does the Ld code mean on a calypso Kenmore
Hello there
LD means a long drain
it is taking longer than 8 minutes to drain out the tub
please check the following
First unplug the machine to prevent electrical shock·
Check wiring harness to ensure they are all connected and are not fried
·If needed remove the side panel and Check the hoses going to pump for clogs and all drain hoses and drainage system
· Check circuit board that controls the pump to see if any wires are burnt or have failed
once the faulty part or the clog has been cleared simply plug in the machine and press the cancel button and resume your normal washing operation
Hope this has been very helpful for you
Best regards Michael
Posted on Dec 30, 2009
Testimonial: "Thanks for the feedback....the water pump had a sock.....Thanks...."
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Ld error code on my kenmore elite calypso washer
Please recheck on your replacement and see if the harness was connected to the right socket.
Click this link: Pump
Jan 25, 2013 | Kenmore Washing Machines
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
My Kenmore Elite Calypso is displaying the letters LD and will not start.
Assuming this is a WASHER, and not a dryer - LD is an error code for Long Drain.
This means the pressure sensor has not reported the tub to be empty after a certain number of seconds.
Usual causes - due to poor design - are the outlet line strainer being plugged with coins, legos, panties, socks, etc... or the pressure switch (or tubing) failing.
Remove the pump's inlet line (outlet from tub) and check that the line is cleared of foreign objects.
If it is clear - move to the pressure switch. Many times the tubing is cracked - or moisture has developed inside the tube. Remove it from the switch and attempt to blow in the tube.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2010 | Kenmore Elite HE4 Electric Dryer
What does the Ld code mean on a calypso Kenmore Elite Washing Mashine
Hello there
Dec 30, 2009 | Kenmore Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
I have a kenmore elite top load calypso wash motion at the end of wash cycle it does not spin and flashes a LD on display I have to turn off and just do a spin cycle to to spin dry.
LD (long drain). possible blockage at pump..check to see if pump spline is stripped. also if the drain hose is plumbed in airtight then this may be slowing the draining process.
Jun 13, 2009 | Kenmore Washing Machines
Washing Machines Logo
301 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
