Question about Panasonic KV-S2026C Pass-Through Scanner
Line in scanned document
One of our KV-2026-c scanners has developed a line down through the scanned document. I have been unable to determine where it's coming from. Any suggestions would be appreciated.
    Problem Solver:
  • 10 Answers
Its dirt! It takes just one tiny speck of dirt on the lens to make a vertical line.
We have some scanner maintenance videos;you want to clean the CIS front sensor.
Regards,
MyEfact
Posted on Dec 22, 2010
I have a line that runs down the center of all the documents I scan. What can I do?
On your scanner, there is something (dust?) that is blocking that part of the scanner from scanning that column on the scanned document. Clean the scanning-head.
Jun 08, 2011 | Canon DR-2050C Path-Through Scanner
My panasonic kv-s2026c has a black line running down the left side when I scan my documents. I have cleaned the rollers, used air canister to see if anything is stuck in there. That didn't help
On the CD that came with the scanner is a directory called "Shading Utility". Copy this folder to your PC. Put a blank piece of copy paper into your scanner. Open up the Shading Utility folder and then double-click on the shadingutility.exe. The password is "GOSHADING" without the quotes. This process will take a few minutes but it will re-align the lens in the scanner which has gotten out of alignment through vibration. This is what is causing the vertical black line on the left side of the page.
Jan 13, 2011 | Panasonic KV S2026C Path-Through Scanner
Why do I have a black line down the side of my scanned documents?
If you are using the ADF (Automatic Document Feeder) there is likely debris in that section of the scanning glass. The ADF parks the scanner in place and moves the paper over it, if something is on the scanner it will show up as a line. Check the thin section of glass at whichever end of the scanning deck for dust and clean it with a dry towel. If this is happening with documents on the scanner bed the debris is likely in the scanner and will likely need professional servicing.
Jun 09, 2010 | Office Equipment & Supplies
Got a dark line down document when scanner via AFD
When you use the adf, the scanner remains stationary at the far left side of the platen. Check and make sure that the glass is very clean there; use a damp cloth to remove any dirt or other foreign material.
May 27, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
When I scan the pages it has a black line..
Try to peek into the scanner while scanning, you probably have a burned out LED element.
Oct 13, 2009 | Panasonic KV S2026C Path-Through Scanner
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
Black line on scanned document
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
Panasonic KV-S2026C Pass-Through Scanner Logo
222 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
