Question about GE GSS25IFR Side by Side Refrigerator
I have a GE GSS25IFR side-by-side refrigerator that is making a squealing noise. This sound began a month ago where it happened once in the middle of the night and I couldn't identify it. My wife described it happening in the day, but I never heard it until a few days ago. I pulled the unit out and found a fan in the lower right side behind the unit is blowing air through some type of radiator. The tubes were very dusty, so I cleaned it and cleaned the fan blades. The sound was better for a few hours but is now getting worse. It looks like the fan is having problems spinning. I'm guessing it was running too often at some point and now the fan has worn out. I can't find a diagram to identify the part, but I'm sure I can replace it myself since it does not appear to require moving anything with refrigerant and just seems bolted in with a single electrical connector for power. Does this sound plausible, and can anyone provide a part number?
    President:
  • 1,430 Answers
Yes replace the Condensor Fan Motor.
The fan cycles on an off whenever the compressor runs. You will want to replace it right away or your compressor can burn up from the heat. The radiator thing you cleaned is the condensor this is what takes away the heat.The part # is AP4298602 enter your model # or the part # at www.appliancehelponline.com the part is in stock and on sale.
Posted on May 12, 2010
Electrolux side by side model ew28bs85ks4 icemaker was making a grinding noise and just quit completely no ice what to do?
If you can watch the icemaker run through it's cycle, with the door open of course, try and determine where it might be hanging up.
I 'trimmed' part of the replacement kit installed by our Electrolux repair technician where it was hanging up with the motorized parts, about 5 months ago, and it began completing it's full ice-making cycle once again.
Mar 28, 2014 | Refrigerators
I have a ge side by side refrigerator/freezer and i'm hearing a sizzling sound from the freezer side. Sounds like water is hitting the heating element causing a sizzling noise. Should I empty th
If you are sure the sound is coming from the freezer side, then yes you should empty the frrezer and take off the rear shield. While the heating element is normally encased in glass or plastic. Water droplets hitting an electrical connection could also cause a sizzling sound.
Feb 03, 2012 | GE Refrigerators
My GE Profile Dryer is only 14 months old. A couple months ago a soft squeal began whenever I use the dryer. I only average 2 loads a week at the most and sometimes less than that. Of course, the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 07, 2011 | GE Profile DPSB620GCWW Gas Dryer
I have side by side refrigerator GE GSS25IFRF BB MOD FH234420 IS NOT RUNING PROPERLY AND ALSO HAVE A SOUND LIKE A CLOCK AND TEMPERATURE IS NOT COLD
The control board on the rear of the refrigerator is making the noise because it has gone bad.
The control board must be replaced.
Mar 30, 2011 | GE GSS25IFR Side by Side Refrigerator
We have a GE GSS25QGTA CC side by side and the icemaker stopped working. The water still dispenses on the door without a problem. There is ice build up behind the ice cube container. Iuse a blow dryer to...
look for a reason that the ice is building up . it sounds like a defrost problem and the coil is being blocked with ice . this is caused by the defrost cycle not working . it may have a bad defrost heater of timer . either could cause this.. do ck the tempt in freezer if must be 15 deg or lower for ice mker to work . . mm feed back [pls )
Jan 01, 2011 | GE GSS25IFR Side by Side Refrigerator
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25QGTA BB side by side frig
mikethemonk If there are no ice cubes stucked in the icemaker, you have to call GE for service. Your icemaker could be guaranteed for three months only. Gendos...post back
Feb 24, 2007 | GE GSS25IFR Side by Side Refrigerator
GE GSS25IFR Side by Side Refrigerator Logo
160 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
