Question about Acer Aspire 3610 Notebook
The screen quit and I need to turn on the external monitor port
    Guru:
  • Acer Master
  • 1,705 Answers
Look on your keyboard, along one of the top 2 rows you'll see some symbols as alternatives to the main key function. One will be a small picture of a TV screen.
Press the key Fn and the small screen key together.
Posted on May 12, 2010
How to turn on
What?............Oh, okay.............I was going to watch this Disney movie though..........
JUST KIDDING!
http://www.asus.com/ph/Notebooks_Ultrabooks/ASUS_VivoBook_X202E/
1) Laptop OFF, monitor OFF, attach a VGA monitor to the VGA port, on the laptop.
(Right side, all the way to the back)
Or you can use the HDMI port, and use an HDTV.
The HDMI port is on the Left side.
Turn the monitor/TV on.
Turn the laptop on.
Does a display show on the external monitor/TV?
No?
Hold the Fn key down, and tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
Go to what you are using as an external monitor. VGA monitor, or HDTV. Hold the Fn key down, and tap the F8 key until you get what you want.
Have a display on the external Monitor/TV?
Problem is NOT the graphics chipset.
Problem is the Video Cable, or LCD/Touch screen.
Post back in a Comment, as to the results of the external monitor test.
Regards,
joecoolvette
F8 key is display toggle over
Apr 25, 2013 | ASUS VivoBook X202E-CT033H Touch Laptop, 1...
Unlock password
How about looking at a screen?
Use an external monitor
Briefly;
Your laptop has an external display device port. (Connector)
I do not know what it is, because you didn't state the laptop manufacturer name, and model number; Elizabeth
It may be a VGA port, or HDMI port, or Mini-HDMI port; or DVI port
http://en.wikipedia.org/wiki/VGA_Connector
(Scroll down for VGA Cable example)
http://en.wikipedia.org/wiki/HDMI
(You can click on any photo, and it will enlarge)
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Laptop OFF, monitor OFF, connect the external display device to the laptop.
(VGA = Monitor. DVI = Monitor. HDMI, and Mini-HDMI usually = HDTV. They all compromise an external display device)
Turn the monitor/HDTV on.
Turn the laptop on.
By factory default settings, the display should show on the external display device.
IF not;
There are at least 3 display options. For this example I'm going to use a VGA monitor.
(For a VGA monitor you can use a CRT type of monitor. Looks like a small TV. Or you can use a flat LCD screen monitor, if it has a VGA Cable attached)
The basic 3 display options using a VGA monitor are;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno. Laptop manufacturer name, and ......................
It will be one of the F keys at the top. F1 through F12.
The Function key will have a monitor icon on it, and usually an arrow on one side........Or perhaps two monitor icons sitting side by side.
(Empty rectangle is a monitor icon)
Still no display on external display device?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key
[If memory serves for Display Toggle-Over key;
HP = F4
Acer = F5
Toshiba = F5
IBM/Lenovo = F8
Don't write that in stone, however.......]
Once you post the manufacturer name, and model number; then I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
Toshiba m35x starts /stops intermittently with no power to display monitor
By whom Kathleen? You?
I ask because there are two ways to answer this;
1) You performed the procedure, and less for me to post.
2) You did not perform the procedure, and I need to explain from the beginning; using a diagnostic flowchart, pictorial guidance, and guidance from me.
While I wait for your reply, suggest perform this simple test first;
Laptop OFF, monitor OFF, attach an external monitor;
1) VGA monitor to RGB (VGA) port on left side of laptop.
Can use a CRT type of monitor (Looks like a small TV), or flat LCD screen monitor if it has a VGA cable.
OR;
2) S-Video port on left side of laptop for TV, or external video display device
http://en.wikipedia.org/wiki/S-Video
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external monitor. (Display device)
If not there are 3 display options available;
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold the Fn key down, and at the SAME time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Display on external monitor means there is a problem with;
A) Video Cable
B) screen Inverter
C) LCD screen
Which means if computer display was working correctly before;
1) Whoever repaired it could have used the external display option, and it needs to be set back to internal
2) The Video Cable connections are not tight, not correct.
Loose at motherboard, screen Inverter, or LCD screen.
3) Anti-Static Procedures were NOT followed, and laptop is now an expensive paperweight.
Regards,
joecoolvette
Apr 05, 2013 | Toshiba Computers & Internet
How do I hook a an external monitor up to a hp dv6 1355 with a cracked screen?
http://h10025.www1.hp.com/ewfrf/wc/product?product=4043282&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Product specifications;
External Ports:
1 VGA (15-pin)
Manuals > Notebook Tour - Windows 7;
Left-side Components - External Monitor Port
Left/Rear side of laptop,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
(You can also use an HDTV if it has an HDMI port, and you have an HDMI cable. The HDMI port is on the Left side of the laptop, too.
{Don't buy an HDMI cable that is expensive. Just a waste of money.
Those gold plated parts are just a little bit better, than an HDMI cable that doesn't have it. $20 for an HDMI cable is PLENTY. (12 Feet) I use one's that cost less )
A) Laptop OFF, monitor (External display device) OFF.
Connect the VGA monitor to the VGA port, on the laptop.
Turn the laptop on.
There ARE at least 3 display options available;
1) Internal monitor ONLY
2) Internal monitor AND external display device (VGA monitor in this example)
3) External display device ONLY
Press, and hold the Fn key down, tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
Wait a few seconds.
Still no?
Hold the Fn key down again, and tap once more on the F4 key.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 15, 2012 | Computers & Internet
Gateway M275 display scambles
I suspect it may be a problem with the video cable coming from the convertible tablet, up through the hinged support for the LCD screen, AND/OR the screen Inverter.
I would like you to connect a VGA monitor, to the VGA port on the back of the convertible tablet. The VGA monitor will now be an External Monitor.
[ Looking at the rear of the convertible tablet, start at the Left side.
Vent, USB port, Monitor port. The Monitor port is the VGA port ]
The VGA monitor can be a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
Notebook OFF, monitor OFF, connect the VGA monitor to the M275's VGA connector. (Port)
Turn the monitor on. If a CRT type, allow it to warm up.
Turn the notebook on.
By the factory default settings, whatever is shown on the convertible tablet's internal monitor, should now be shown on the external monitor.
(VGA monitor)
If not, press, and hold down on the Fn key (On the bottom row of the Keyboard, all the way to the Left), and tap once on the F3 key.
(Top row of Function keys. The F3 key is the Display Toggle-Over Key )
No graphics shown on the external monitor? Hold down on the Fn key again, and tap the F3 key again.
There are at least three options available;
1) Convertible tablet's internal monitor - ONLY
2) Convertible tablet, AND external monitor
3) External monitor - ONLY
If graphics are fine on the external monitor, you have a problem with the video cable, and/or the screen Inverter. At this time we will bypass the LCD screen, and come back to it.
At the bottom/middle of the tablet's LCD screen, is the Hinge. The Hinge Cover is 'T shaped', and has one single Philips screw holding it on.
If you remove the screw, and the Hinge Cover, you will see two wire harnesses.
One Black, the other White.
See that these two cables are plugged in tightly to the connector.
After checking this step come back in a Comment, and state your findings.
Regards,
joecoolvette
[ Additionally;
Here is the Service Manual (Free) for the Gateway M275 Convertible Tablet,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Where it states - Gateway 400, go down to the second line, and across to M275. Left-click on M275.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Dec 11, 2011 | Gateway M275 Tablet PC
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
My computer was working fie. i closed it for a second and when i opened it again the screen was black. the back light still worked but the screen was blank
Try testing it out through your external ports like the vga, svideo (hdmi if you have one) port to a external monitor, or a tv and see if you get anything there. If you are able to get display to a tv, or external monitor through your external port, then you might have a issue with your screen inverter, or loose connection somehwere between your screen and your laptop base. Secondly if you can't get a display to a tv or external monitor using the external ports, or you get the same display like your screen, then your vga chipset is screwed, and you motherboard will need replacement since the vga chipset is solder onto the motherboard. At this point you can either try to replace the motherboard, (which is going to cost you almost or more then a brand new laptop) or decide to go ahead and get a new laptop.
Feb 01, 2011 | Compaq Presario CQ60-220US PC Laptop
My laptop has a black screen. The lights are on and I can hear the motor and fan.
I'm assuming that when you turned it on, all you got was a black screen (you didn't say anything different).
First, make sure your laptop screen has been chosen as the display screen. On each laptop, there is a Fn and special function key combo that will allow you to switch between the laptop and an external monitor. Press that combination of keys several times.
Next try to boot in safe mode by restarting the computer and pressing F8 until you see the menu.
Next, connect an external monitor to the SVGA port.
If none of these is working for you, your video card has most likely quit on you.
Jun 14, 2010 | Computers & Internet
SCREEN WONT TURN ON
Connect an external monitor (CRT or LCD) to the laptop's "VGA-out" port. Then, turn your laptop on. Does it show the usual "start-up" screen, on the external monitor? If so, then either your laptop's screen is totally-dead, or the "LCD-inverter" (a $20 part that takes $50 for a technician to replace) needs replacement.
Or, does your laptop have a key-sequence (LCD-screen-only, LCD-and-external, external-only) that needs to be used to select LCD-only mode?
Apr 23, 2009 | Computers & Internet
My screen wont turn on
Hiya, have you tried plugging in an external monitor to the Blue VGA port of the laptop ?
If so, do you get any display then ?
Hint : you need to plug in the external display 1st, then turn on the laptop. If the External monitor doesn't come on, then you may need to press the Function key on the laptop & the F4 key (Or whichever shows a monitor logo) to get the laptop to switch to external monitor.
If you CAN get display on the external monitor then the problem could either be that the Invertor for your laptop screen has blown, or, the backlight for your Laptop Screen has broken, or the Laptop screen itself has gone faulty. In rare cases, the cable from the Laptop Motherboard to the screen may be faulty or have come away form the connector on either end.
Hope this helps.
Mar 19, 2009 | HP Compaq Presario F750US
Acer Aspire 3610 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
