Question about Pentax K1000 35mm SLR Camera
The shutter is stuck...all I see is black
The shutter is stuck...I can move the film as if I am going to take another picture, but when I look through all I see is black and the button you press to take the picture is stuck.
  • 55 Answers
Your second curtain is not releasing the mirror to come down.
This happens with weak 2nd shutter curtain tension.
If the wind lever is stuck and the mirror does not come down then the mirror tension spring came off.
Posted on Jun 17, 2010
The screen unexpectedly went blank and black....apart from camera info symbols..all pictures taken now are black..... pictures taken before can be seen on screen,....lens moves in and out ok
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Nikon COOLPIX S220 Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
The pictures are coming out black.
Sounds like the film is not exposed, shutter not opening. If possible fire the shutter with the camera open/back off, pointed towards a light source, if the shutter opens you will see the light thru the shutter/lens. If no light is seen then the shutter is stuck.
Oct 28, 2010 | Polaroid MiniPortrait 203 Instant Camera
My film in Canon ae 1 came out blank :S
I would say either the film didn't wind properly as it was going along,or the shutter isn't working properly.Did it make the whirring noise like it was winding after you took a picture?If you can,try taking a picture with the door open,no film,and see if the shutter moves.If it does open,it's probably the winder which pulls the film after a picture is taken.Good luck!
May 01, 2010 | Canon Photography
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Same thing here on my D40. Was on a camerastand (tripod) and fell (toppled over). Everything seems normal apart from the error mentioned above. Can't take pics neither (black), and shutter error....
I can help you understand what is going on with your problem, but it is a problem you should not try and fix yourself. When your camera hit the dirt, it probably broke the shutter mechanism.
The symptom you mentioned with the black pictures means that the shutter (allows light to the medium) is not moving.
When you take a picture, the shutter moves very fast. It is what regulates how long light hits the medium (regular cameras, it's film, in digital cameras, it's the ccd.)
Bottom line, your going to have to take it to an authorized repair shop for the make of your camera. Probably be around $200. to repair. Sorry for the bad news. Let me know what you think in a comment if you want, and thanks for coming to FixYa. Feel free to rate my answer.
Rob
Feb 23, 2009 | Nikon D40x Digital Camera
My Kodak Easyshare LS443 is taking black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Dec 15, 2008 | Kodak EasyShare LS443 Digital Camera
N55 Shutter Problem
If the shutter blades get bent they are hard to straighten out. Better to find a local repairman or you could do more damage to the shutter. Sorry to be the bearer of bad news.
Jun 11, 2017 | Nikon N55 35mm Film Camera
Canon EOS Rebel G - The picture is cut in half
I'm afraid this is almost certainly a shutter fault - the second curtain of the focal-plane shutter is getting stuck half-way across the film and therefore not shutting properly. The fact that the other half of each frame is OK makes me think that the second curtain is not sticking totally but just moving very slowly for half of its run, thus seriously overexposing that half of the film. This is a repair shop job - unless you want to try it yourself: it may be just some dirt stuck in the track the shutter curtain runs in, but a fair bit of skill is needed to get to it & clean it without damaging anything!
Sep 29, 2007 | Canon EOS Rebel G 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
1,078 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
