Hi, my tv has white and black spots all over the screen. What can it be. It is getting worse. Please help
  • Ahmose Avin
    Ahmose Avin May 12, 2010
    thank you so much for your help
  • 10,515 Answers
Let me know the Make and Model of the TV?
Do you see the same Spots even when you run DVD player or PS3 or any external device?
Do the Position of the Spots Changes? or it is Fixed?
When you press Menu, the Menu would be Over the Spots or Behind the Spots?
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 12, 2010
  • 3 more comments
  • Ahmose Avin
    It's a HLS4676sx/xaa. Its like that on tv and dvd. Yes the dots are on top of the menu screen.
  • Ahmose Avin
  • taran_2005
    taran_2005 May 12, 2010
    Thanks for your response!!
    This Samsung DLP Model is Prone to White, Black and Shut Off Problems. There could be 2 Possibilities :-
    1. Failed DMD Board ( Digital Micro Mirror Device ).It will Steady Get Worse.Cost of Repair for a Technician is around $ 500 - $600.
    If you Order the Board, it Does not come with DMD in many Cases so i have left this out should you decide to do it yourself.
    http://www.tristatemodule.com
    If you want to Repair it yourself, you need a Service Manual which could be bought from :-
    http://www.manualsparadise.com/
    It is not easy to Replace DMD Chip without Alignment issue's.
    2. Failed Panel. This is a Common Problem with Most of the Samsung DLP's.As the Menu is behind the Spots and they are Fixed i would also doubt Panel.
    Let me know,if needed further assistance.
    Hope i helped you.
  • Ahmose Avin
    ok so its not the chip and it is not the optical block. So I should replace the DMD board. How much will that run me.
  • taran_2005
    As we Discuss, there could be many Possibilities. But,i have seen DMD the most Frequent in this Model with same symptoms. It could be Panel.
    The New DMD Board could be around $200. You could go for used one like :-
    http://cgi.ebay.com/SAMSUNG-DLP-TV-DMD-B...
    Hope i helped you.
Fix a lot of white spots on mit65dlp serial wd65737
The white spots are pixels that are burned out. They will just gradually get worse. You will need a new screen or just replace the whole TV. Probably buy a new one for what it will cost to get a new screen put in it.
Nov 29, 2014 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
Bought a 70" TV at Best Buys a few months ago and now it's developing white spots. What can be done to fix this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 31, 2014 | Televison & Video
Grey spots black screen
could be a dead pixel you can some times get them back by tapping the pixel with the stylus off a nintendo ds have the tv on a white screen when doing it so you can see when it has worked. need to tap just the pixel square do it to each pixel.
Sep 29, 2013 | Samsung PS-42A450 42" MULTSYSTEM PLASMA TV...
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
White and black spots on screen
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Samsung HL-S4266W 42" HDTV
My LCD has green spots
i have the same problem in black color but its not my screen i belive its only in vista
Apr 20, 2007 | Vizio L32 32 in. LCD HDTV
TV Bars
These are called vertical retrace lines. They are going to get worse untill you find the bad capacitor(s) or replace the vertical driver/output IC. Please, if you have not the solid state repair experience, get a pro to assist you in this repair as there are no user replaceable parts inside this set. Good Luck PLease do not forget to rate this thread.
Dec 11, 2006 | Curtis CM27002S 27" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
