Question about Braun WK200 AquaExpress Electric Water Kettle White Electric Kettle
I dropped the kettle and the parts from the lid came apart. I want to try to put them back together.
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
Feb 05, 2016 | Kitchen Appliances - Others
How do i put the lid back together on a moulinex serie f30 after taking it apart for cleaning
One shouldn't take things apart if one cannot re-assemble them :D
Take it to your local vac shop.
Oct 29, 2014 | Vacuums
Lid breaking apart cuisinart electric kettle
Check with Cuisine art themselves, ask to speak to someone in spare parts.
Aug 10, 2014 | Kitchen Appliances - Others
Auto-shutoff stopped working
It just has to do with a thermal cutoff that it got hot enough
Nov 30, 2013 | Hamilton Beach 40870 Electric Kettle
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
What company manufactured lid switch PS350434 FOR WHIRLPOOL WASHER
3949247 is the actual part number for that lid switch, and you won't find a blow out of the thing taken apart because its a molded part and not designed to come apart/
Jun 03, 2012 | Whirlpool Washing Machines
The lid of the kettle has got out of place and cannot be closed
should be two screws on top under lid by hanle and two on bottom this will allow the handle to come apart should be able to reajust lid.
Feb 27, 2011 | Kenwood 100JKP Cordless Electric Kettle
My Braun electric kettle won't click on. Do I need to replace the kettle or is there some way it can be fixed?
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Jan 16, 2011 | Braun WK200 Cordless Electric Kettle
B1765 tefal Kettle lid will not remain closed. I
Use a dremel and cut 2-3mm of the plastic away from each side of the sliding latch. This allows the latch to extend to its normal position. Works as new!
Oct 31, 2009 | Tefal Kitchen Appliances - Others
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
May 16, 2009 | Braun WK200 AquaExpress Electric Water...
Kitchen Appliances - Others Logo
Top Braun Kitchen Appliances - Others Experts
Oscar Netto
Oscar Netto
Tom Chichester
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
