Question about Maytag HYE3658AY Electric Dryer
Have a HYE3658AYW dryer that will not power up. It was suggested a fuse was blown. I have not seen fuses in dryers before. Does this dryer have fuses? If so, where are they located?
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerHave a HYE3658AYW dryer that will not power up. - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turnHave a HYE3658AYW dryer that will not power up. - 2_bing.gif />
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
Our Whirlpool dryer model #LER7646AQ0 will not start. Door switch checks for power with a power tester. Put new start switch in and still doesn't work. Do I need to use Ohm tester or will power tester...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Jan 11, 2011 | Dryers
Ihave a whirlpool electric dryer that just stopped working. i was told there is a fuse i need to change. can you tell me which fuse and where it is located?
If you look in the back inside of the machine where the plugin is. There is the power supply/high-voltage transformer. THis provides power to the unit. Next to it should be a fuse. Either a ceramic or a glass bus type fuse. There should be a thin wire inside of the fuse. The wires can break and then the fuse is no longer any good.
Feb 07, 2010 | Washing Machines
I have no power
Check all your breakers/fuses panel if none are tripped or blown we will assume power is @ the outlet, check it w/ a meter if you have one. I have never seen a reset button on one before but there could be a internal fuse inside the unit, to check for that you will have some disassemble work 1st
Oct 25, 2009 | Dryers
Dryer wont dry, element comes on and off, model HYE3658AYW
Could be the thermal fuse. look online for your model and it should tell you where it is located. once you find it olh it out and see if it is open, if so it's a simple and cheap fix.
Aug 12, 2009 | Maytag Dryers
Dyrer runs no heat cannot locate fuses
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 20, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer is not heating
Check the following.
2. Heating element
3. Thermal fuse
Jun 25, 2009 | Whirlpool LER5636P Electric Dryer
DRYER NOT GETTING HOT GEQ8858
CHECK THE FOLLOWING--
2. Heating element
3. Thermal fuse
May 31, 2009 | Whirlpool GEQ8858H Dryer
Drum Turns, but dryer won't heat up.
If the dryer does not heat at all then is either a problem with the heating elemet , or with the thermal fuse.
See the following suggestions from Repairclinic:
There's no heat If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer taking a long time to dry
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Mar 30, 2008 | Amana DLE330RAW Electric Dryer
No power!
The thermal fuse may be blown. The fuse is a white plastic item located behind the back cover on the blower box housing. It has two blue leads attached to it.
  1. Unplug the dryer.
  2. Remove the back cover.
  3. Identify the thermal fuse (white, two blue leads, one screw)
  4. Remove the two blue leads.
  5. Using a multimeter set to ohms, check the continuity of the fuse, it should "peg" the meter if the fuse is good, if the meter does not react, the fuse is blown.
  6. Remove and replace the fuse. Replacements can be found either online or at your nearest Sears.
Nov 01, 2007 | Kenmore 64952 Electric Dryer
Maytag HYE3658AY Electric Dryer Logo
714 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
