Question about Cyberhome CH-DVD 300 DVD Player
WILL NOT TURN ON
This is probally 4 years old maybe? But very low hours. It will not turn on, any ideas or common problems? Thanks
  • midwayautosa May 12, 2010
    FUSE LOOKS GOOD, PULLED IT OUT AND PUT IT BACK IN.
    I think I need the c-10 and c-11 capacitors as zappal posted. Any ideas on how to get them? Thanks
    Guru:
  • 1,705 Answers
A couple of thoughts.
1) Is there a fuse in the mains plug to be checked ?
2) While disconnected, take the top off, have a look at the main circuit board, close to the power in cable, is there a small fuse there which may have failed?
Posted on May 12, 2010
  • dgsturt May 14, 2010
    I can't think of any suppliers off the top of my head other than Maplins in the UK.
    I did however google "electrical component suppliers" and a whole gambit of options were given.
Why do young child struggle in daily routines?
There are many reasons a young child may struggle with day to day routines. The most common reason is their attention span. Up to the age of 5 years old, a child usually has one minute of attention span per age, so a 2 year old has a two minute attention span, a 4 year old has a 4 minute attention span, and so on and so forth.
The second most common reason is that they are given too much responsibility too soon. While children can help with chores at all ages, the chores need to be age appropriate, so you might give a 2 year old a dust rag to wipe a table with but you wouldn't give them a vacuum cleaner of course.
Another common reason is that children don't get nearly enough sound sleep these days. Infants and toddlers need on average 12-14 hours of sleep a night. Some may be able to get away with as few as 10 hours, and others may need as many as 16 hours of sleep a night. 3-5 year old's need anywhere from 10-13 hours of sleep a night and some need as many as 14 hours of sleep a night, while others can survive on only 9 hours of sleep a night. Older children in the 6-13 range need a minimum of 9 hours a sleep a night, and the average child in that range needs 10-11 hours of sleep. Some get by on as few as 7 hours while others need as many as 12 hours. No child under the age of 13 should be sleeping less than 9 hours a night. If they are, it could be one of the reasons that you struggle with the day to day routine, especially if it's the morning routine.
Other common reasons for a child having a hard time with a day to day routine is the need for a nap, not drinking enough water, too long of a wait between meals or snacks that's causing low blood pressure, and distractions by siblings, video games, etc.
Jan 04, 2017 | Preschool
Tv is dead
Common issues are no power reaching set, fuse in set bad, power supply to the set (inside). But if set 12 years old parts may no longer be available.......maybe too old to be a good repair?
Nov 02, 2012 | Haier HL26B Television
I have a 4 year old Samsung Plasma. While watching tv, the tv will turn off and then keep trying to turn back on, but is never able to turn back on. We unplug it, then after 1/2 hour it will work again...
Good day!!!!
You have a better chances if you have failing bad capacitors on the power supply board...
bad capacitors sometimes bulged on top,sometimes not...if the caps is bulged you can easily identify it..
Thanks for using fixya..
Aug 04, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
I am not sure if my Acer mini tower X1700-U3700A has the correct CMOS battery. Currently there is a cr3032 in it or maybe it's a 2032. The computer is booting, however twice in 4 months I've had to...
Why do you replace it? Is the date / hour wrong after a shutdown? 4 months? It should last 4 years or more... Something's really wrong with the board. check capacitors too.
Mar 05, 2011 | Computers & Internet
I HAVE A SAMSUNG 50" REAR PROJECTION. wHEN YOU TURN IT ON IT STAYS ON FOR 1 MIN THEN GOES OFF. wE STILL HAVE SOUND. tHE SET IS 4 YEARS OLD. Any ideas. Thanks
model number would be great
it could be two things here
1:the lamp is all ready burning out they are only good for 6000 life hours if you never replaced it is time to do so 4 years is a long time
2:It could be the color wheel do you here any grinding,humming noises or color problems if not take a look at it might not be spinning anymore and most likely all ready broken all ready
hope this helps good luck
Aug 20, 2010 | Televison & Video
MY DREMEM Mini model #750 doesn't hold a charge all the time and it's only a year old and used once a month. I used it for dog nails. Any ideas?
Hello. Your problem is so common. It is due to the low capacity of the battery and the fact that it will discharge a little each day. Plan it so that you charge it for an hour before you use it. J.
Aug 01, 2010 | Dremel Garden
I have a 4 year old Whirlpool CB60 fridge freezer
turn your control knob to 3 and that should control the appliance....what number have you had it on???
Oct 25, 2017 | Refrigerators
Raypack Pool Heater
A starter would probally be a start capacitor for the blower motor. If you can wiggle wires and get it to start it is more probally a bad wire or a connection. If you clean all the connections check the wires expecally at the point where they go through zip ties and the like. Also check the air sensor connected to the blower housing by a hose and the wires connected to it.
Apr 24, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Hunter Fan Model 44260 eats batteries
you have to replace the thermostat . problems like this are common with latest electronic thermostats from china . most are going bad in less than 4 years . it so bad ,i am telling anyone who asks , to please keep there old regular thermostat , or if you have one of the old electronic ones (made over 10 years ago) hold on to it , it will last forever.... somehow when we moved the factory to china they forgot how to make thermostats that last ........ if you plan to rate this answer , please rate it 3 or 4 stars . this will help me stay in the paid answer department
Apr 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
GE television 32GT740 Guideplus Gemstar
6/1/2010 11:34:21 AM
Good morning I have sound problem it started with the cable hook up there box to the television, now sound is very low. Turn up the TV control to max, nothing but low sound. Of course cable people have no idea of a problem, I disconnected the cable but the same problem, love the set work for two years, note: thing happen when all analog change to digital. help!
Dec 12, 2008 | GE 32GT740 32" TV
Cyberhome CH-DVD 300 DVD Player Logo
185 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
