Question about GE DVLR223 Dryers
Loud squeeky dryer - GE DVLR223 Dryers
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryerloud squeeky dryer - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
Dryer makes squeeky noise when drying
What brand is the dryer and is it front load
or regular?
Apr 20, 2014 | Kenmore 800 7982 Dryer
Loud squeeky noise
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 22, 2011 | Dryers
Dryer has starting making loud squeeky noise when engaged. This has only developed in last 2 weeks. Suggestions for problem/repair?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 28, 2011 | Maytag MDE5500AYW Electric Dryer
Squeeky noise in the back of dryer when running?
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
May 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Squeeky dryer
Typically what happens is over time the back drum supports wear out. Once they have worn thin the drum rides on the bare metal portion of the support and you get the "annoying" speek sound. Or if the supports are the roller bearing type, the bearing fails and it generates the noise.
Anyway, the supports or rollers are inexpensive to replace and not very difficult.
If you want to tackle the problem, let me know.
Good luck.
Regards,
Jun 22, 2009 | Frigidaire GLER331A Electric Dryer
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Squeeky back break
could the pads have already worn down so fast?  has anyone had this problem?The higher the humidity the more noise mine makes not so loud as to be a squeal but noticeable. I kind of doubt they are worn out. You may have a shoe thats glazed that would do it also. The linings may need to be lapped down at the edges. Any drum brake rear bike squeals if the edges are higher than the center found that out on a Suzuki GT 250 I had 25 years ago. ,,,
Nov 10, 2008 | 2005 Enfield Bullet Electra
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
GE DVLR223 Dryers Logo
313 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
