Our four year old Kenmore 700 series washer quits in the middle of some cycles (quits about 60% of the time). If I turn it off and move the dial a bit forward, things resume normally. Otherwise, everything sits there in the water forever. Help.
  • oldguy5 May 12, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
  • juxtapose111 May 12, 2010
    All I can find is Kenmore 700 Series model number 27741600. Is that enough?
  • 5,911 Answers
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles. If the lid switch is loose, or has worn contacts, it can cause erratic problems.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back with your MODEL NUMBER and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on May 12, 2010
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
We have an Kenmore 70 Series Heavy Duty Plus washing machine that is about 20 years old. The washer stops after the wash cycle and we have to manually move the dial one notch. The washer then completes the...
This is the deal, your washer is way to old to fix. The board is going bad and that is why it will not cycle properly. It would cost about $150.00 to fix and that does not even include labor. Consider craigslist as you can find some great deals from 40-60 for a newer one. Hope this helps.
JimmyC
Sep 26, 2009 | Kenmore Washing Machines
Need to know if my old washer has a lint filter
The large set of numbers is 81350130.This is the model number and it was at one time preceeded by 110.
The small set of numbers on the bottom right of the tag is C44904453. This is the seriel number.
The small set of numbers on the bottom middle of the tag is 9.8 60 120,
9.8 Amps
60 HZ
120Volts AC
Kenmore washers with the pre code of 110 are Whirlpool products. Many years ago (1986) the new design was elimination of the lint filter. The only way to lessen the effect is to wash linty clothes together and not to overload. While the machine is washing lift the lid and watch the clothes. If they are circulating (appears and disappears)from top to bottom ands remaining in the same general location you are good. If the same item is staying visable all the time and the clothes are just wiggling a little you have too much in there.
(I repaired these for 21 years)
Eric
Jun 08, 2009 | Kenmore Washing Machines
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 90 Washer dial isn't calibrated correctly
push the knob to off and turn knob only to you left...off is in..always unplug unit first
Nov 03, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
250 people viewed this question
Top Washing Machines Experts
