Question about Dell Inspiron 1000 Notebook
OPERATING SYSTEM WILL NOT GET PASSED STARTUP WINDOW
  • 40 Answers
Run an OS repair. Or try pressing f8 to boot in safe mode
Posted on May 12, 2010
Inspiron 5110 slow startup
Assuming you are using windows 7...in the run window type msconfig
After the window opens up, click on the startup tab and uncheck anything that you don't want to start automatically when windows starts. Becareful in here though, you can disable your windows if you aren't careful. You may also want to run your antivirus to make sure that nothing is hogging your resources at start.
Nov 23, 2012 | Computers & Internet
I need to find a set up disc
What operating system set up disc are you referring to ?
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options.
Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window.
Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid
windows xp pro start up disc
http://systemdiscs.com/?utm_source=neosmart&utm_medium=article&utm_campaign=Vista_Recovery
vista recovery disc
Hope this helps.
Nov 20, 2012 | Computers & Internet
Reboot and select proper boot device
You cannot start a virtual machine in Microsoft Virtual PC 2004 Service Pack 1 (SP1) or in Microsoft Virtual Server 2005 from a third-party startup CD or from an ISO file that contains a third-party startup CD image.
When you start a virtual machine that does not have a guest operating system, you receive the following warning message:
Reboot and Select proper Boot device or Insert Boot Media in selected Boot device.
If you insert a startup CD for the operating system into the physical CD drive, or drag an ISO file that contains a startup CD image to the CD icon in the status bar of the virtual machine
window, and then press ENTER, Virtual PC 2004 and Virtual Server 2005 will ignore the operating system that is on the CD or on the CD image.
hope this helps
Jul 14, 2012 | Dell Computers & Internet
Your computer was unable to star
Hi Dear,
Your system windows (Operating System) was corrupt, so you have two option in your hand first you should format your PC and install the new window (Operating System) & second you repair you old windows(OS) if you have windows CD then try this link to repair & format PC. if you chose first option then you all data will delete, & repair window your data will not delete.
Option :
1.For Repairing you OS (windows XP)
2.For New OS Installation (Windows XP)
If you are using difference OS version let me know.
Thanks
May 21, 2012 | Acer Computers & Internet
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
What may be the problem of my pc because it always restart?
You need to get the exact error message to determine the cause of your system restarting. Then post again with the error message that will appear.
If you're using Windows XP:
  1. Navigate to the Control Panel in Windows XP by left-clicking on Start, followed by Settings and then choosing Control Panel.
  2. In the Control Panel window, open System.
    Note: In Microsoft Windows XP, depending on how your operating system is setup, you may not see the System icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
  3. In the System Properties window, click on the Advanced tab.
  4. Locate the Startup and Recovery area and click on the Settings button.
  5. In the Startup and Recovery window, locate and uncheck the check box next to Automatically restart.
  6. Click OK in the Startup and Recovery window.
  7. Click OK in the System Properties window.
  8. From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're using Vista/7:
  1. Click on Start and then Control Panel.
    Tip: In a hurry? Type system in the search box after clicking Start. Choose System from the list of results and then skip to Step 4.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the System icon and proceed to Step 4.
  3. Click on the System link.
  4. In the task pane on the left, click the Advanced system settings link.
  5. Locate the Startup and Recovery area and click on the Settings button.
  6. In the Startup and Recovery window, locate and uncheck the check box next to Automatically restart.
  7. Click OK in the Startup and Recovery window.
  8. Click OK in the System Properties window.
  9. You can now close the System window.
  10. From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
Jun 12, 2010 | Computers & Internet
I can't restart my window vista laptop solve plz
Windows Vista is not starting due to missing or corrupt files.
Run Startup Repair using Vista Operating System disc
  1. Place the Windows Vista Media Backup DVD into to the optical drive and start the computer.
  2. Press any key to boot from CD or DVD.
  3. On the Install Windows screen, click Next.
  4. On the Install Windows screen, select Repair your computer.
  5. In the System Recovery Options dialog box, click Next.
  6. In the System Recovery Options dialog box, select the appropriate operating system, and then click Next.
  7. In the System Recovery Options dialog box, select Startup Repair.
  8. The Startup Repair attempts to locate and resolve issues with the computer.
  9. If prompted, Do you want to restore your computer using system restore?, click Restore.
  10. In the System Recovery Options dialog box, click Finish. This screen can vary, dependant on if a problem was found or not.
  11. System restarts.
  12. If the problem was resolved, the computer restarts into Vista.
  13. If the problem was not fixed, the error may present itself again.
  14. Run Startup Repair again.
  15. If Startup Repair runs more than three (3) times, when available, select View advanced options for system recovery and support.
  16. For further troubleshooting, select one of the following options:
    • System Restore
    • Command Prompt
    • Last resort - Recovery Manager. Recovery Manager is not available if accessing WinRE via Vista OS Backup Media DVD
or you can use any software that can repair and recover your windows files.
Best regards
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
Problem with botting my system......plese reply
The solution for this issue would be...
In order to get this issue fixed... What needs to be done is as follows...
1) Right click on My Computer...
2) Then in the drop down menu... Left Click on Properties....
3) Then you will get the system properties window...
4) In System Properties Window... Go to the Advanced Tab...
5) Under Advanced Tab Click On Startup & Recovery Tab.
6) Under Startup & Recovery Uncheck the option's which says time to display OS 30 seconds.. Uncheck both the options
Jan 22, 2009 | Microsoft Windows XP Professional
About my pc
try disabling the automatic restart on system failure
You will get a chance to read the error message and codes.
Jul 07, 2008 | Computers & Internet
System restore
Specifying the Default Operating System for Startup loadTOCNode(2, 'summary'); If you have more than one operating system on your computer, you can set the operating system that you want to use as the default one for when you start your computer: • Click Start, click Control Panel, and then double-click System. • On the Advanced tab, under Startup and Recovery, click Settings. • Under System startup, in the Default operating system list, click the operating system that you want to start when you turn on or restart your computer. • Select the Display list of operating systems for check box, and then type the number of seconds for which you want the list displayed before the default operating system starts automatically.
To manually edit the boot options file, click Edit. Microsoft strongly recommends that you do not modify the boot options file (Boot.ini), because doing so may render your computer unusable.
Feb 19, 2008 | IBM ThinkPad R31 2656 Notebook
Dell Inspiron 1000 Notebook Logo
46 people viewed this question
Alun Cox
