Question about Maytag Dryers
I have a Maytag Dryer Model # SDE405 DAYW and it will turn on and dry for a while then shut off. It keeps doing this repeatedly. So i have to open door let it cool and turn it back on ....and so on and so on.... what do you think the problem is?
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
  • 94 Answers
SOURCE: Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Posted on Oct 14, 2008
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
SOURCE: Maytag Atlantis MDG8400AWW Dryer Runs Cool
I had a similar problem years back. It was the ignitor. The ignitor is a ceramic like piece that heats up (glows red) that ignites the gas. Typically when that goes, you will see some white residue build up where it cracked, thus breaking the electrical connection. This thing works like a heating element on an electric stove, but rougher looking.
The part was about $30 at my local parts store. I bought an extra one just in case so I have it on hand. I installed it with common tools.
You can check it to see if you lost connection by using a volt meter.
Good luck.
Posted on Jun 23, 2009
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
Maytag model MEDC400VW0 continues to run after drying cycle is completed
Sometimes these machines have a cool down cycle which for most people is too long
Dec 15, 2014 | Maytag Centennial 7.0 Cu. Ft. Super...
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
How do i get dryer apart to get to heating element model mde308 dayw
unplug dryer, move out from wall so you can get to the back. use a 1/4" nut driver and remove the rear panel. The heater element is on the bottom right. before replacing check for continuity. if the heater has continuity, check all of the other componets on the rear of the dryer. i would advise to check the small white thing with 2 wires connected.
Apr 29, 2012 | Maytag Dishwashers
Dryer does not shut off automatically anymore, it just keeps drying until i open the door. How do i fix?
may be the timer motor, here is a website that will show you how to test it:
http://www.partselect.com/dryer+test-timer+repair.htm
Oct 24, 2010 | Maytag PYE2300AY Electric Dryer
Automatic dry cycles do not shut off
its poassable that the dryer is not drying well.check your house venting.if your clothes are drying well before it shuts down.your sensor bars may have a wax buildup on them.use a rag and a mild cleaner and clean the surface of the sensor bars.good luck!
Jan 17, 2010 | Maytag Dryers
Maytag dryer runs and tumbles but will not heat up to dry clothes. model # LDG7500AAW, serial # A3351803. it does have flame but will not stay hot. Is this a thermostat problem?
I would suspect a faulty high limit thermostat is causing this problem. It is usually a small round, black device mounted on a small plate and attached to the internal ductwork with two screws. Hope this helped and best wishes.
Aug 05, 2009 | Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
