Question about Black & Decker B2250 Bread Machine
First time use. set machine to dough and pressed
First time use. set machine to dough and pressed start, the blade is not turning. Dumped everything out to make sure everything was securely attached and it was, reset to dough and started with same problem. What have I done wrong?
  • 433 Answers
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
Posted on May 13, 2010
How do I put a delay start in the dough setting on a B&D B6000c bread maker
You can not in any machine use a timer delay on the dough setting. Sorry.
Feb 18, 2015 | Kitchen Appliances - Others
I was given a regal bread maker model k6751 is the kneading blade supposed to turn the whole time?
No, the blade only turns when the machine is in a mix or knead cycle. There are many minutes where the blade does nothing. This is when your machine is allowing the dough to rise or at the end during the bake phase.
Nov 07, 2013 | Kitchen Appliances - Others
When the blades are inserted do they have to click into place? Mine just sit loosly on the shafts--but do go completely down to the bottom of the shaft---however, the dough is not mixing or rising or...
Most bread machine paddles fit kind of loose so you can get them off for cleaning. Try turning on your machine like you were going to bake a loaf but don't put any ingredients in. Just watch, you won't hurt anything doing this, you are just trying to see if your paddles are turning or not. If they are turning then your problem is something other than the paddles.
Oct 05, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
How do I set the dough setting on the machine
Once you have your ingredients in the pan and the bread pan in the machine you close the lid and plug it in. Now you need to push the menu button until # 8 displays in the left hand side of the display screen. This is the setting for the dough cycle. The cycle time will display to the right of the cycle number, they will be in bigger numbers than the dough cycle number. The time is 1:30 for a 1.5 lb loaf and 1:40 for a 2 lb loaf. Now you need to select the crust colour and the loaf size. Now press the start button and the cycle will start. I have included the link to the owner's manual in case you don't have one. I hope this helps you. Good luck!
Carol.
http://www.useandcaremanuals.com/pdf/B220,B2250984.pdf
Feb 02, 2009 | Black & Decker B2250 Bread Machine
I need a manuel for my bread maker chefmate hb-12w
Here's the instructions for Model HB-215. Source =>
http://www.globalgourmet.com/forum/index.php?topic=47.msg222
The post below this post says Chef Mate - Models HB12W, HB215 and CM725 only! So, it might be the same instructions.
Chefmate Bakery Oven Model HB-215
Modes:
  • Standard 1.5 lb normal crust: Bakes a 1.5 lb basic loaf of bread in 2 hrs 30 min.
  • Standard 1.5 lb dark crust: Bakes 5 min longer.
  • Standard 1 lb normal: Bakes a 1 lb basic loaf of bread in 2 hrs 20 min. No “dark” option.
  • French mode: Bakes a French loaf of bread (salty taste) in 3 hrs 40 min.
  • Sweet mode: Bakes a sweet flavor loaf which tastes like a butter roll in 3 hrs 40 min.
  • Doughmode: Use this mode for making dough for rolls, croissants, doughnuts,etc., which you want to bake in your conventional oven. Prepares doughin 1 hr 20 min.
Control Panel: (when pressing a controlbutton, be sure to hold it down until you hear a “Beeping” soundindicating contact has been made.
  • Display: Shows the time remaining until a mode is completed. Can also display timer setting or mode selected.
  • Select button: Push to select mode: Cycles through modes in following order:
    Normal 1.5lb -> Dark 1.5 lb -> 1 lb -> French -> Sweet -> Dough
  • Start button: Push to start processing the mode selected.
  • Stop button: (press for one second to take effect)
    Push to turn off power after baking is completed or to reset the mode or timer.
    If used after a mode is started, it will stop it.
  • Timer set buttons: Up arrow: advances timer setting 10 min each time pressed.
    Down arrow: sets timer setting back 10 min each time pressed.
Ingredient Information
  • Flour– Use flour that is marked “bread flour” or “better for bread”. (Thesewill usually be labeled as having more gluten than regular flour.)
  • Dry Skim Milk – This enhances the flavor and adds to the nutrition of the bread.
  • Butter – Butter adds a rich flavor to the bread and makes it soft.
  • DryYeast – Yeast is necessary for causing the dough to rise. Select readyto use yeast which needs no preliminary fermentation. Use only activedry yeast. Don’t use 50% faster dry yeast.
  • Sugar – Sugar speeds up the dough rising process, adds flavor, and makes the bread soft and the crust brown.
  • Salt – Salt controls the activity of the yeast and makes the dough firm.
  • Water– Gluten is formed when flour is mixed with water. This allows thedough to rise by retaining air. The amount of water and its temperatureare very important. Usually, the water temperature should be between 68F/20 C and 77 F/25 C. When the room temperature is over 82 F/ 26C, usecold water (about 41 F/5 C). When the room temperature is under 50 F/10C, use lukewarm water (about 100 F/38 C).
Operating Instructions
Baking a standard loaf of bread using Standard Mode.
Ingredients for 1 lb loaf for 1.5 lb loaf
Water 7 ½ ounces (210ml) 9 ½ ounces (270ml)
Bread Flour 2 1/3 cups 3 cups
Dry Skim Milk ½ tablespoon 1 tablespoon
Sugar 1 tablespoon 1 ½ tablespoons
Salt 1 teaspoon 1 ½ teaspoons
Butter 1 tablespoon 1 ½ tablespoons
Dry Yeast 1 ½ teaspoon 1 ¾ teaspoons
1. Open the lid and remove the bread case (hold both sides of handle and turn counterclockwise.
2. Position the kneading blade on the drive shaft. (remove any crumbs from drive shaft.)
3. Place ingredients into the bread case. Add ingredients in the following order:
Pour in the proper amount of water.
Add the flour, sugar, salt, butter, and dry skim milk – in that order.
Place the dry yeast on the center of the flour.
Note:When using the timer, make a hollow depression in the ***** of flourand pour the dry yeast into it. Do not let the yeast touch the water orthe dough may not rise properly.
4. Place the bread case into the body of the baker. Turn clockwise to lock
5. Close the lid.
6. Plug in to outlet. (after being plugged in the number “0 00” will flash in the display.
7. Setthe standard mode. Press the select button to set the mode to Normal,Dark, or 1 lb, depending on your preference and the amounts ofingredients used.
8. Start. Press the START button. The timereadout in the display will begin counting down the minutes from theamount of time required for the mode you have selected.
Steam may rise from the vent on the back of the lid during operation.
When baking is finished, the buzzer will sound three times and the display will read “0 00”
9. Removingthe bread case. When the buzzer stops, press the STOP button and openthe lid of the baker. ( The heater in the unit will keep operating tokeep the bread warm for a while after baking is complete. When removingthe bread case, always be sure to press the STOP button to turn off theheater.) Using the handle and oven mitts, remove the bread case. Thehandle and bread case will be very hot. Do not place the heated breadcase on the body of the baker, table cloth, or plastic surfaces.
10. Removing the bread from the bread case.
Usingoven mitts, turn the bread case upside down and gently shake it toremove the bread. The surface of the bread case is slippery, so be sureyou have a firm grip.
If the bread can not be easily removed, turn the drive shaft on the bottom in both directions so loosen the bread.
Place the bread on a wire rack or similar surface to cool.
Note: when baking is completed, remove the bread as soon as possible. If leftin the case for a long period of time, its surface will become stickyand the flavor will be lost. If the kneading blade comes out with thebread, use a plastic or wooden utensil to remove it. CAUTION: it willbe hot.
11. Remove the plug from the outlet.
Baking a French loaf of bread using the French mode
Follow the above instructions, except select French mode in step 7 and use the following ingredients in the order shown:
Water 9 ½ ounces (270ml)
Bread Flour 3 cups
Sugar 1 ½ teaspoons
Salt 1 ½ teaspoons
Butter 1 ½ tablespoons
Dry yeast 1 ¾ teaspoons
Baking a sweet flavor loaf of bread using the Sweet Mode
As above, but select Sweet Mode in step 7 and use the following ingredients in the order shown:
Water 7 ounces (200ml)
Egg (medium size) 1
All Purpose Flour ½ cup
Dry Skim Milk 2 tablespoons
Sugar 2 tablespoons
Salt 1 ½ teaspoons
Butter 3 tablespoons
Dry Yeast 1 ½ teaspoons
How to use the timer. (The timer function cannot be used with Sweet or Dough modes)
The timer extends the time from pressing START until the baking completes.
1. Place all ingredients into the unit and plug it in.
2. Select the desired mode
3. Press up arrow once. The normal time for that mode will be displayed: 2:30 for a standard loaf.
4. Keep pressing up arrow (or down arrow) until the desired time to completion is displayed.
5. Press the START button to start the delayed timing.
Preparing a dough for handmade bread using the Dough mode.
1. Follow steps 1 through 6 for standard loaf. Select Dough mode in step 7.
2. Press START to begin the dough making process. It will take 1 hr 20 min. The display will show the time remaining.
3. Thebuzzer will sound 3 times to let you know the dough is ready. Take itout and shape it as you wish for baking in a conventional oven.
4. Unplug from outlet.
Dec 30, 2008 | Kitchen Appliances - Others
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Black & Decker B2250 Bread Machine Logo
135 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
