Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I was using my sears craftsman riding mower yesterday and it was working fine...no issues whatsoever. I stopped the engine to get something and when I went to re-start it, the engine turned over just fine, but whenm I attempted to remove my foot from the brake, the engine would shut down. What causes this and how can I resolve it?
    President:
  • 1,627 Answers
You should check the seat safety switch,it may have stuck or is unplugged or it needs to be replaced.Any other safety switch that is unplugged or defective would keep it from starting.
Posted on May 12, 2010
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
Riding lawn mower battery won't hold a charge
It is a battary issue, however it sounds like the engine is not charging the battary so it goes flat, or there is a drain on the battary .
Jun 27, 2013 | Craftsman Garden
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Engine hesitates and dies when hot, restarts fine, then dies agai
Check the fuel pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman Garden
I have A craftsman riding mower 18 1/2 hp 42 inch deck have changed spark plugfuel filter took off tank and blowed it out but the mower still cute off after about 10 minutes like it has no gas what else...
Do you have a Briggs or kohler engine.I am having the same problem.I have changed the fuel filte, fuel pump, and cleaned the carb.Sears has been no help at all.The reason I ask about the engine you have is that people are having the same problem no matter what engine they have.So therefore it probably is not the engine so it is something else on the mower.My mower runs fine for about 10-15 then starts to stutter and backfire.I am continuing to pursue this problem and I will post back here if I come up with anything.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower suddenly shut off and engine starting smoking. Now it won't do anything. seems to be locked up. Sears craftsman riding mower only 1 and a half years old. has oil and gas.
About the first thing I would do is to pull the plug lead(s), tilt the mower up (resting it on something solid) and see if the motor shaft could be turned at all. I suspect you initial thought that it is locked up is correct.
May 15, 2010 | Craftsman Replacement Belt for 42" Deck
Motion belt slipping craftsman 2000 42" hydrostatic
Irritating problem, Have you checked your rotor heads to insure there free spinning? They could be gummed up and need lubed causing high resistance against the belt.
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower will not start or brake
The two are seperate issues. The switch on the brake pedal is on the frame and is accuated by the pedal, not the rod or spring. If you are not confident with a voltmeter or test light, then the Sears tech will be the fastest thing to mowing again.
Nov 08, 2009 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
853 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
