Question about Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher
Moyer diebel model 301HT - water does not drain out
    Problem Solver:
  • 40 Answers
Could be the drain hose is kinked or partially blocked
Posted on Feb 14, 2014
4 Suggested Answers
  • 86 Answers
SOURCE: Moyer Diebel Dishwasher arms are not spinning and doing lousy
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is dickson@lau.com God Bless Have a nice day, Dickson
Posted on Jul 02, 2009
  • 86 Answers
SOURCE: Moyer Diebel model DF 3- pump dispenser, the
Your sanitizer wont" go through the line , the best and the cheapest way is to change the 3 squeeze tubing together, or if you like you can change the one you know is defective. You have to know the 3 pump is working when the cycle is on. Let it run a complete cycle and you can see the pumps running or not. If the pump is not running then you may have a burned out motor in your samitizer system.
Posted on Apr 12, 2010
  • 13 Answers
SOURCE: We have Moyer Diebel model
The drain flap/mechanism could be faulty or the hose in the back does not have a high enough loop and is siphoning back into the dishwasher.
Posted on Apr 22, 2011
Moyer Diebel 301 always draining
what I can tell you is that if the water temp is not high enough say 120 deg, the dishwasher washing cycle will extend.chk your drain hose and float valve for fill drain issue.
Feb 12, 2014 | Moyer Diebel 24 in. 301HT-40 Built-in...
Water comes out of the vacuum breaker when I use the dishwasher. I am not sure but seems to happen on rinse.
Possibly the seat in the vacuum breaker is not seating properly. Repair with a repair kit, which includes a plastic piston with a rubber seal. Could also leak if the water pressure is weak.
Jun 18, 2011 | Moyer Diebel 24 in. 301HT-40 Built-in...
We have Moyer Diebel model 401HT, serial #w2384. The water is not draining out.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 14, 2011 | Moyer Diebel 401HT Dishwasher
What is the hlts booster, and how do I turn down the temperature ?
hlts is a high limit thermostat and usually can be reset. To turn down the temperature usually involves adjusting another thermostat with a control knob.
Jan 01, 2011 | Moyer Diebel 24 in. 301HT-40 Built-in...
Stuck in wash cycle... timer bad?
Possibly the booster is not reaching proper temperature.
Sep 06, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Moyer Biebel commercial dishwasher
Open the cap on the vaccum breaker. Check the float that is inside and insure that the seal on it is not worn or split anywhere. if it is, replace.
Apr 23, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Rinse temp too low, first it comes up to 180 degrees and then drops to wash tank temperature, WHY?
The rinse temp only reaches 180 degrees for a couple of seconds towards the end of the cycle. This will sanitize all warewash and meets most health code regulations. The rinse water temp will drop rapidly as it is incorporated in to the machine and sprayed on the dishes.
Regards
Feb 23, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Not using detergent or rinse aid
Do you have a Manual for your machine, if not get one in USA 800.858.4477 in Canada 800 263 5798 we goes from there. God Bless Dickson
Apr 28, 2009 | Moyer Diebel 24 in. 301HT-40 Built-in...
Installing a used dishwasher just need to now how big of drain line is needed the one on this lookes bigger than most dishwashers can i reduce it to smaller ruber hose
Most hardware stores should have plastic reducers that slide on your drain hose,then attach the correct size to the reducer to drain.
Apr 07, 2009 | Moyer Diebel 24 in. 301HT-40 Built-in...
Moyer Diebel 24 in. 301HT-40 Built-in Dishwasher Logo
313 people viewed this question
Top Moyer Diebel Dishwashers Experts
Are you a Moyer Diebel Dishwasher Expert? Answer questions, earn points and help others
