Question about Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive
External Hardrive Issue
I have a Toshiba USB 2.o externl drive which I have been using for about1 year and today it appears not to be working. When connected to the computer it dies not appear when I go to my computer. The light is on and when plugged in to the computer I only receive the USB Sleep and Charge information.
Desperate for my files
Betina
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Is this an IDE externl drive
IDE is an interface, used inside your PC, so no, it isn't IDE. This drive is designed to be plugged in to your USB 2.0 port, and that is its interface. So unless you want to take it apart and use the HDD from inside, you will not need to know.
Nov 27, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
I have a Toshiba 1Tb External Hard Disk. When I plug in my drive, the drive gets detected in the systems tray but the drive does not appear in 'My Computer'. Please provide a remedy for my
If your using xp, right click on my computer, click manage and then disk manager and see if the drive is in thereright click and you can explore the drive, if t not in there go to device manager and see if the drive is in there if not try in different usbports on your machine if same issue try on a different PC if possible and if same issue drive is faulty, contact toshiba for replacement (although they take ages to replace a drive)
Sep 18, 2011 | Toshiba 10TB USB 30 Desktop External 1 TB...
I bought a brand new fantom drive externl hard drive used it once and now it wont show up when i plug it into a usb port
Try to plug the external hard drive to a different port. if its not working try to use other usb device like ipod, or thumb drive and if the other usb device works it means the problem is the external hard drive it self. If the problem still the same the problem is the usb ports probably the motherbaord
Sep 03, 2011 | Fantom Computers & Internet
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
Archos AV500 / USB harddive
from what i gathered with my archos 5 it is due to a power issue so the archos does not provide enough power to make the external hd work
Mar 08, 2009 | Archos 605 WiFi Digital Media Player
Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive Logo
173 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
