Question about Sony Cyber-shot DSC-W50 Digital Camera
Won't take a picture
Get a black screen that says access. Won't snap pic, with-out delay, then the pic. is all white. Won't turn on or off with-out removing batterie. Lens will not move in or out if it is out, won't go in, will not work. I am able to view pics already on the camera and delte. After removing batteri and putting back in. Please help. Need to be able to use the camera for vacation starting tomorrowThere are several different things showing on screen when turned on something in the right hand corner don't remeber seeing before says SAF with a symbol, a large M top left hand side, some other symbol I can't make out and an eye shape symbol with something under neath of it saying on
top right hand side says 10m Fine,arrow 101 underneath says 666, a page symbol underneath another symbol. can you help???
  • jemcc1013 Mar 30, 2008
    I have the same problem. It says access and my lens will go in and out but at a certain point get stuck. The message changes and says turn your camera off and on again. Please help!!!!! I don't want to buy another one!
  • etw20 Apr 08, 2008
    Mine does the same thing, the screen turns white and then freezes and I have to remove the battery
  • 477 Answers
I work on these cameras all the time you have a ccd going out or has gone out that is causing the auto sensing feature to now work their for the camera stops working. 1 other thing it might be could be the main-board but they don't go out as often.
Posted on Apr 10, 2008
Fuji finepix won't connect to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Oct 17, 2012 | Cameras
Top and bottom screens are white
Sorry for the delay. If the dsi won't turn off when you first get the white screens, hold the power button for 8 seconds. The unit should go off. Take the game cartridge out of the unit and inside that cartridge slot, is a reset button. Using a toothpick or something, press it. Turn the unit back on and it should be fine. Hope this helps :D
Nov 13, 2011 | Nintendo Dsi Pink Console
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
Why does my camera have now have a white screen and I can hardly see the pictures..what's wrong with it?
I have a Konica Minolta camera Dimage Z3 that was given to me so I dont have the manual I have the box and cords to it .The promblem is the screen is white it won't let you take pitures you can hear it taking the pics and it will flash but you can't see anything but a white screen. Does anyone know about this type of camera? Thanks so much!
Sep 24, 2010 | HP Photosmart R927 Digital Camera
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Pictures are almost white
check the picture selection rotary switch is set to "auto adjustment" or"programme auto",for perfect pics.
Aug 14, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Picture Display delay
Here is the location of the manual. You may also have to download the firmwhere updates that are located in this website also.
http://support.nikontech.com/faqid=14541
Good Luck!
Dec 16, 2008 | Cameras
Screen problem??
This sounds like a cracked screen.. a leaf you say? is the leaf a graphic, perhaps an icon.. is it centered on the screen at all?
hmm....
I would take it to a certified repair center to see if they can replace the LCD panel.
Sounds like it needs to be replaced.
Oct 31, 2008 | Cameras
Sony Cyber-shot DSC-W50 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
