Question about Bose Wave Radio
Im trying to wire up a aftermarket radio in a 91 acura legend but need to no what color the remote power and igntion wires are
  • 311 Answers
Http://www.the12volt.com/installbay/stereodetail/82.html
where is alist of what wire does what in a 1991 acura legend
also i recomend that you use a voltmeter and double check that the infor the website is telling you is correct in your car
Posted on May 12, 2010
91 Acura legend won't turn over. Changed the starter relay and checked the starter, it's good. Now what do I do?
Power flows from Fuse 35 50A to IGN switch. Start by checking that fuse. From IGN switch to starter on black/white wire. Check for battery voltage on that wire at starter. If no voltage, check for voltage on black/white wire at IGN when turned to START. If no voltage, check for good power coming into the IGN switch on the the white wire from Fuse 35
Feb 04, 2018 | Cars & Trucks
Im hooking up a pioneer car stero in a 2001 chevy cavalier. I purchased a chevy plug n play wire harness, and I hooked up all the wires (color coded) and plug it in, but no power, I have A ground and a...
your adapter should be color coded to the pioneer wiring, orange, red and yellow are power feeds for igntion, 12 key and lighting, veryify voltage on the orange and red wiring to the radion with key on, the yellow is for radio lighting with parking or headlight operation, some adapaters may not have all the wiring and you may have to splice around the adapter.
Jan 03, 2018 | Car Audio & Video
The radio code for a 91 acura legend 2 dr
The code was issued on two cards that came with the car documentation. If they are not with the car anymore any acura dealer can give you the code if you go there with the car. The code is matched to each car's vin number so they will need to see that the radio is in the car.
Nov 20, 2010 | 1991 Acura Legend
I need to know what wires are what in my dash for my radio in my 2000 grand prix please nothing is labeled like it should be for example it says red wire is accessory I dont have a red wire the closest...
first things first check your fuses and i mean all of them replace all that are bad with proper fuse amprages
you are going to have to do some probing of those wires to find the ones you need you can buy a voltmeter(25$ or less) or a simple test light(2-5$) from a local automotive store
colors to look for are
primary power wires :red,yellow, black for ground
accsesory wire from igntion ,orange or blue with wite stripe and posibly pink(rare)
any wire that has an on and off state from the turn key igntion can be used depending on its gauge/size test the orange one first as this is the most common color to use for the accsesories wire
to test you have the igntion in the on postion if you get a readying of +12 volt and then turn the igntion of and recive a reading of 0 volts this would be an on off wire
note: check the auxsilary postion of the turn key igntion also if there is no power to the wire in the auxzilary postion it is the incorect wire for the radio
BLACK> should be a ground wire
RED>should be an igntion supply wire of a larger diameter
YELLOW> should be a battery supply lead strait from the fuse box battery conection "always on"connect the wire of the stereo labeld battery to the always on battery lead ,this is for the memory function of the radio
ORANGE>(may be pink only seen pink in buick's) should be an on/off wire from the igntion and used for the main power of the radio so it is shut of when the car is turnt of this is also the wire you would hook the amplifyer on off up to if the radio dont supply the blue wire with white stripe aka ant/motor
test the on off state of the wire befor conecting it to the radio
you will conect the red (+ positive) wire to this on/off state wire
cation! disconect the batery ground wire when conecting anything to the main yellow battery wire as it is directly conected thru an exspensive(12$) 30 amp fuse
if you dont know what wires are what for the speakers in the car use a 9 volt batery to find the speaker wire leads (ues a brand new 9 volt)
ntsc standard color pairs are
white and grey front
green & brown for back
i dont remeber the left and right
the black stripe on the speaker leads means the ground or negative side of the speaker
good luck instaling your new radio hope i have helped you out
Feb 24, 2010 | 2000 Pontiac Grand Prix
Connect (-) power up cable to my four windows acura legend 1192
havent a clue to be truthful,does the kit come with a wiring diagram ,i should imagine that their is a central block with 4 outlets ,one for each window that connects to teh earth side of the window winder motor.if you have a diagram with instructions then i could tell you more sorry
Oct 24, 2009 | 1992 Acura Legend
I need a coloring wire diagram for a 1989 acura legend door
If the year is the same, the colors should be the same. There are diagrams in Chilton or Haynes manuals but they can be misleading. Remove enough tape wire so you can see the color(s) and re-check before you electrician tape everything up. To be slick you could use "shrink" tube insulation. Work on one harness at a time. Elect.windows and mirror should be separate "feeds".
Oct 21, 2009 | 1989 Acura Legend
91 acura legend will not start
Take off the hose to the throttle body and look for any obstructions. This has been know to cause performance issues similar to those described
May 07, 2009 | 1991 Acura Legend
Radio wiring
Get an aftermarket wiring harness from Advance Auto PArts and ****-Connect them.. or Take it to a radio shop..
Mar 17, 2009 | 1991 Ford Thunderbird
No brake lights/lamps on 91 acura legend
Check for bad wiring at the 3rd brake light. You may find frayed or broken wiring there.
Mar 01, 2009 | 1991 Acura Legend
Bose Wave Radio Logo
59 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
