Question about Sylvania Televison & Video
Why wont my remote work, its not due to the batteries because i have put several new batteries in it and it still will not work
  • lgraf547 May 12, 2010
    I can not get the last screw out, but yes this solution was somewhat helpful. thank you for your help.
  • 10,515 Answers
I am Sorry to Hear Regarding the Problem. Unfortunately, it seems that the Remote is at Fault and it's the Time to Go for a Newer One. I wish Every Remote could Last Forever.
The Few things you could Try before Grabbing a New Remote :-
1. You already Tried Changing the Battery. So, Basic Step is already Taken.
2. You need to Clean the Connectors with a Cleaning Solution. Sometimes, Dust and Dirt Might affect the Working of Remote.
3. As there is no harm, You could Dissemble the Remote. Clean and again Assemble it. It might work as Charm.
If the above 3 Steps would not work, it seems to be a case of Faulty Sensor ( remote ) which is Quite Common. The Only Option is Replacement as Repair is never a wise Option for these remotes due to the Cost of the Defective Part.
Note - I am buying that there is nothing wrong with TV.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 12, 2010
Why wont my gargage remote open the door from the outside
I had to extend the antenna wire on mine due to metal siding when I put a steel door on
Sep 13, 2014 | Sears Craftsman LiftMaster Chamberlain...
The television wont change channels, only power and volume work,
also check remote control if it the rubber contacts are clean. sometimes moisture seeps into remoted. and several times semiconductor rubber contacts loose their properties with friction and pressure.Try to remove batteries of the remote for several minutes and press buttons to discharge any current stred into capacitors. Put the batteries back into remote and try it.Otherwise Try another of the same remote or there may other problems with TV IR sensor. or switching circuit.
Apr 08, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
What type of battery do I need for my remote. Stopped working, so I bought a new batter DL2025 and now the remote only works sporadically. What type of battery do I need to use, please?
2035 is thicker than the 2025 which if you are using the thiner one it is not making good contact. They are the same voltage, but the 2025 also wont last as long due to less reserve.
Mar 12, 2010 | Bose Wave music system large Remote...
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
'95 Nissan Maxima-Alarm goes off-then windows & doors won't work
Open the drivers door panel and locate the inside lock cylinder, there is an alarm switch that wrap around it with an electrical wire came out, it might also have another one on the passenger side in some other model . What it does is arm and disarm the alarm when you use the mechanical key and in some other model, it also lower the window when you disarm. The switch might pop out of place or deteriorated due to age. Good luck all.
Mar 22, 2017 | 1995 Nissan Maxima
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Won't work on my television
I spilled a drink on my remote and it dosent work tryed new batteries nd still wont work can i get a new one i also have the dish hoked up to the tv
Feb 25, 2008 | Philips PM435S Remote Control
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Intermittant remote
yes they do go bad. try cleaning the inside of the remote and check for a bad solder connection with-in the remote. the key pad can get dirty from your handling maybe a good cleaning but do not scrub it just lightly touch the pad with cue tip and alcohol
Dec 12, 2006 | Toshiba CZ36V61 TV
Televison & Video Logo
18 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
