Question about LG Dryers
My LG TDC70045E SILVER Tumble Dryer drum slips
My LG TDC70045E SILVER Tumble Dryer drum is slipping only by a few millimetres every rotation. It seems there is some play in how it is fixed - looking at the inside of the drum, at the back, there are five spigots it is sitting on, and it moves about on these spigots. It is about 3 years old.
captaynkyrk
  • 170 Answers
SOURCE: Drive belt replacement on a Miele T230C tumble dryer
You must route the belt either in front of or slip it behind the drum to get it down to the drive wheel. You should remove the front panel to be able to do this the best.
Posted on Jul 06, 2008
AlmostBob
  • 550 Answers
SOURCE: BELT WON'T TURN THE DRUM
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Posted on Aug 28, 2008
  • 1122 Answers
SOURCE: tumble dryer drum wont rotate is it my belt .if so how do i replace it
yes it is the belt,what make and model number(inside dryer door or on it,let me know and we can go from there-mike
Posted on Oct 02, 2008
  • 2692 Answers
SOURCE: DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Posted on Jan 07, 2009
MNfisherman
  • 11896 Answers
  1. This doesn't appear to be a simple task so I would suggest making sure you have the time to do this so your project does not get interrupted.
  2. Step 2 1: Remove power (better now than later ;-) )
    2: Remove the front door assembly (2 screws holding the hinge to the drier carcase)
    3: Remove the top cover (2 screws at the rear, then slide the top backwards and lift off). It's a good idea to remove any fluff from the innards at this point.
  3. Step 3 4: Lay the drier carefully on it's front (I used a pillow to protect the timer and 2 pushbuttons)
    5: Remove the cover over the drum bearing and earth strap (2 screws)
    6: Remove the cover over the fan assembly (numerous screws)
  4. Step 4 7: Remove the earthing bracket (copper assembly held by 2 small screws) and then remove the circlip and washer on the drum axle
    8: Remove the fan vanes (3 hex screws holding 2 metal flanges that make up the impeller fan)
    9: Remove all screws around the rear cover and gently lift it up (I supported one edge with a basin perched on the rear of the drum, it gives access to the motor chassy etc. There's a vent tube that will come dislodged at this point; it's easy to relocate later.
  5. Step 5 10: Remove any bits of the old belt and drop the new one round the drum. Use tape to hold the belt in the correct position on the drum (if you don't do this, you WON'T gave enough slack to go round the motor pulley....believe me!!)
    11: Carefully feed the belt past one idler wheel and then over the motor pulley. Slowly turn the drum slightly to encourage the belt to feed round the second idler wheel.
  6. Step 6 12: Remove the tape used to hold the belt in place
    13: Replace the rear cover (make sure the vent tube is seated correctly at front and rear). Tighten all screws.
  7. Step 7 14: Replace the Fan assembly
    15: Replace the drum bearing circlip (I took the opportunity of rotating the bearing through 180 degrees). Replace the copper earthing strap.
    16: Replace the fan housing cover and drum bearing cover. (Make sure the heating element is free of fluff and crud)
  8. Step 8 17: Replace the top cover
    18: Fire up the beast!!! It may smell a little if there's anything still on the heating element.
Posted on May 22, 2009
When dryer turned on a humming sound is heard, but the dryer does not start(drum does not tumble)
Links on how to change dryer drum belt below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Belt Replacement
How to Change Clothes Dryer Belt
How to Replace Dryer Drive Belt Repair Guide Help Sears PartsDirect
Feb 26, 2016 | LG Tromm Electric Dryer
Lg tdc70045e dryer
Sounds like your motor has packed up
Jun 13, 2013 | Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
Fit belt on Tricity Bendix TM 220 W Tumble Dryer Drum stopped rotating but motor running and element heating up. Took back off and belt seemed to have slipped off. Trying to reattach belt but it seems too...
Check the belt routing over the idlers near the motor, there is a spring tensioner, also make sure idlers are smoothly rotating and not seized.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 24, 2011 | Dryers
My tumble dryer has stopped working, the drum was going forwards, but not in reverse, not it seems as if it is stuck
Sounds like a belt slipped off the pulleys in the back or broke. Remove a few screws on the back panel and it will be very obvious.Good Luck
Sep 19, 2010 | Zanussi TD4100W Electric Dryer
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
I changed the belt on my Creda tumble dryer. Now its making noise
You may have to change the Guide wheel that the drum needs to rotate on
Sep 06, 2017 | Dryers
My dryer won't rotate unless I give the drum a
its the drive belt slipping it needs a new one fitted
Nov 10, 2009 | LG Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
60 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
