Question about Canon PIXMA MP600 all-In-One InkJet Printer
My Canon Pixma MP600 worked fine and now Windows isn't recognizing the device at all. I tried troubleshooting, changing the USB connection and adjusting the port options, but no success. Windows 7 driver is up to date.
  • 1 more comment
  • Lanie17 May 12, 2010
    Just checking to see if there are any other expert suggestions here. Trying to avoid buying a new printer. Thanks.
  • Lanie17 May 13, 2010
    The expert was very helpful and took me through a few steps to help determine that my problem is with the printer hardware. Off to do online research. Oh well.
    @emissionwiz
    This is the first time I tried this site so I have no idea how it works for the experts. I asked for another solution just like I would if a doctor told me I needed surgery. I wanted a second opinion. Thanks for your first solution!
  • 10,515 Answers
Please uninstall the printer software as well as disconnect the printer from the PC then follow the instructions in the link below after that restart the PC and reinstall the software once again.
http://support.microsoft.com/default.aspx?scid=kb;en-us;817900
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 12, 2010
  • 4 more comments
    Thanks for the solution. Nothing is working. The message says that there is a malfunction and that the device isn't being recognized.
    One more detail that may have some bearing on the situation... the devices and printers folder in control panel shows a green check mark on the MP 600 and it also shows an unknown device in the unspecified area. As far as I know, there is no other device not hooked up. Can this have something to do with the problem?
  • taran_2005
    taran_2005 May 13, 2010
    Thanks for your response!!
    Initially what i am trying to do is to make sure whether it is a Software or a Hardware bug.It seems like a Software bug, but as we discuss it could be anything.
    I have seen Certain Registry Changes could result in Non - Function of Printers. The Other Details you mentioned might affect the working of Printer.
    Is that a Possibility that you could set up this Printer on a Different Machine. That would help us to make sure whether we need to Find a Software Fix or Hardware Fix.
    Hope i helped you.
    Thanks for using
    I just connected the printer to my netbook's USB port and here is the same message:
    USB Device Not Recognized
    One of the USB devices attached to this computer has malfunctioned and Windows does not recognize it.
    Does this info help?
  • taran_2005
    Is it the same or a Different Operating System?
    I wanted to make sure that, this is not a Software Issue. In the Past, there were certain issue's like this with a Particular Operating System. Try to use this Printer on Different machine ( with Different O.S ).If the same message, appears then it is Hardware Fault unless it is Software.
    If it is Hardware, then the ball is in your court.There is no harm in giving the Manufacturer a call and ask for the Quote.This is a Common problem, So they would be aware of the same and could let you know a Ball park Estimate and then you could take a Decision from there.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using
    Well that said a lot. I just tried it with a Vista laptop and at first it started to install the driver, but after a second the same message came up that it is not being recognized. So, it's a hardware problem. The unit is about three years old so I guess I should be thankful that it didn't break down sooner.
    What a bummer that all these old electronic pieces wind up in a landfill somewhere. They are never worth repairing. Thanks for your help!
  • Hilary Mayes Mar 03, 2015
    Same problem on 2 different laptops (Win7 & 8). However I followed the instructions in the link provided on my Win7 laptop, method 3 disabling/unistalling the Universal Serial Bus Controllers. It worked! Thank you. Now to check it out on the Windows 8 laptop. If not will try the same remedy on that.
    Top Expert:
  • Canon Master
  • 76,649 Answers
Un-install the software for the printer and then reinstall it, if the computer doen't recognize the printer then the printer is defective and u will need to repair it or replace it, with the cost of repair well over $100 the best solution if the printer is the problem is just replace it, which is the cheaper of the 2 options in almost all cases.
  • 3 more comments
    Can this happen all of a sudden? Working one day and then not the next?
    I tried to uninstall the drivers through Control Panel, but the message says it's in use. I had already turned it off and unplugged the USB connection. Any suggestions?
  • yadayada
    yadayada May 12, 2010
    yes it can happen all of sudden, electronics very seldom give any warning, have seen many printers do this, two of mine have failed this way.
  • yadayada
    I would try doing a system restore to an earlier date when the printer worked, if that fails u need a new printer
  • yadayada
    yadayada May 13, 2010
    I told u in my posts the printer was bad, why do u now accept the same conclusion from another expert? i should get credit for my effort here with a helpful rating from you, that is only fair.
  • yadayada
    I understand what u are saying about a 2nd opinion, but still the credit for the problem should go to the 1st opinion if the other opinions bear out his solution. I get no credit for the right answer.
I have a Canon with a USB connection. Can I connect this to a Ethernet connection on my wireless router? (I had it working thru USB port of apple airport router, but new Verizon FIOS wireless router does...
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
dont forget to vote
Feb 27, 2011 | Canon PIXMA MP600 all-In-One InkJet...
MP600 MFP was working fine then recently can't be found as a USB device. Tried changing cable and USB port on the (DELL) computer and it makes no difference.
hi;
look at the USB connector located on the printer is it broken ?
light it with a torch look inside the 4 pins are they fine ?
Nov 05, 2010 | Canon PIXMA MP600 all-In-One InkJet...
USB device not recognized
try to connect your printer to other computer if still same result have your printer check to see what is the problem with the printer
Nov 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Pixia MP600 had been working fine but now computer with Vista fails to recognize it and says something on connected to USB has malfunctioned. Also where can I get a installation cd that is in English. The...
while you install the software cd . you can see the language settings for display there you can change your own language. dont connect the devices before you install the software cd while you install the cd it will ask you the default settings from there you can change the setings.
Jun 16, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP610 not connecting to scan
Had the same problem. Don't think it scans wireless; worked fine when I connected with USB cable.
May 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600 stopped connecting to computer
try to transfer the usb cable to another USB port..or swap with the another working USB port..and restart your computer..
May 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Uknown device Error - Canon PIXMA M180 All-In-One
well i'm not sure but did u try to change the usb connection itself? or if it doesnt work try to chek if there are any windows errrors but most propably the connection
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP780
The problem is not the printer or the make of printer: The problem lies with the PC
Jul 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
MP600 canon printer computer cannot recognise USB device
Try different USB ports on the computer to see if its a porblem with the port connection and if there's no change there then try using another USB cable that you know is working perfectly fine.
Nov 25, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
178 people viewed this question
old marine
old marine
