MY HP 4700 SCREEN SHOWS 49.3048 SERVICE ERROR AND STOPPED PRINTING...HOW DO I GET THE PRINTER TO WORK.
  • 4 more comments
  • Garyd45 Apr 09, 2008
    My 4100n has the same error code. Cycled power off & 30 seconds later back on but the problem remains.
  • Anonymous May 05, 2008
    Can not print to 4700. Receiving 49.3408 service error.
    I have restarted printer. It comes back up as ready, but when I print to 4700 error message comes back.
  • kidlington Jun 21, 2008
    My Printer HP 4700n has error 49.3048, do you know how to fix?
  • Anonymous Aug 07, 2008
    I have the same problem on a hp 4700. Service error 49.3408
  • buren Aug 21, 2008
    HP 4700dn prints fine on my network but whenever i put it on our out lying network it comes up with this same error 49.3048 service error. Restart and you can print one page before it goes back into the same erroe. Help!
  • ari9 Dec 09, 2008
    I got a 4700N printer got error 49.3048
Puta
Posted on Jun 04, 2008
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Service error 4cf0 hp 4700
Try removing the JetDirect card, then see if the machine will boot and print a test page. If it works without JetDirect, then try replacing the JetDirect card.
Oct 15, 2014 | HP LaserJet 4700 Printer
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Hp 4700 49.3066 service error
49.xx errors are mostly caused by invalid print commands, corrupt
data, or invalid operations. Basically the printer "does not understand" the print job.
- restart the printer to clear the print job from the printer's memory.
-if the error returns disconnect the network/USB cables from the unit and cycle power again.
If the error comes back without the network/USB connected perform a cold reset on the device and go the next step.
- Once the unit is at Ready reconnect the network/USB cable.
If the unit gets the 49.xx error or begins to print a job then gets the error disconnect the cables again and power cycle the printer. This time when you plug the network/USB cable in watch the control panel for any signs of the unit receiving a print job. When the printer says "Processing" press the cancel button on the printer. This should clear the "bad" print job.
I strongly recommend updating to the latest driver for the device Drivers Software . If you had an issue with a PDF file use the Post Script (PS) driver.
Good Luck
Jan 24, 2012 | HP LaserJet 4700 Printer
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
My hp color laserjet printer shows 49.4c02 service error on the screen.
49 errors are usually related to the jet direct network card which may need to be replaced. But if only happens from one user or when printing one particular document or from one particular program then you may have a driver or software conflict.
Aug 30, 2010 | HP LaserJet 4700 Printer
Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Apr 10, 2009 | HP LaserJet 4700 Printer
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Mar 12, 2009 | HP LaserJet 4700 Printer
Hp color laserjet 4700dn error code 59.30
turn off the printer. remove the duplex device from the printer. turn on the printer. enter the diagnostic menu. enter the menu for sensor and motors. select the fuser motor and let it run. if you can hear it its ok (its not such a noicy one ... you have to listen very good) - follow up the next steps:
turn off the printer. turn on the printer. enter the service menu - pin code is: 09470005. set to 0 all counters for mono print, color print and the counter after service. leave the menu.
turn off the printer, reinstall the duplax device. turn on the printer.
result: the error msg is gone. its just HP wants to sell theyr service contracts.
Feb 25, 2009 | HP LaserJet 4700 Printer
Computers & Internet Logo
995 people viewed this question
David Payne
David Payne
