Error code 260 c pitney bowes r 750 meter - Office Equipment & Supplies
Bubbabear64
  • 2794 Answers
SOURCE: Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Posted on Sep 02, 2008
The C180 was made by Panasonic and is no way comparable to Toshiba. The E3 code should flash with another code (01, 03, 11,... etc) This other code is required to diagnose problem and is a service issue. If it is an E3 10 or E3 11 there is a corona wire dirty or broken, these are the most common E3 codes. I'm not sure about other codes, you may have more luck looking for info on the Panasonic 7718 just remember to refence both parts of the code
Posted on Sep 17, 2008
SOURCE: F2-02 Error on Imagistics ZB35 machine
You need to use Sharp genuine toner.There cartridges have a 'smart chip' on the rear of the cartridge.This error code is a direct result in fitting wrong toner.
Posted on Mar 03, 2009
  • 149 Answers
SOURCE: Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Posted on Feb 24, 2010
  • 1294 Answers
SOURCE: copiadora pitney bowes dl 200 error en dispey
The problems is in the fusing unit.Clean the thermistor and heater lamp.Reset the trouble:press the microswitch located in the right side to display pane,under the display contrast button.After appair the * simbol on the display,press 3 and the Trouble reset button.
Posted on Aug 09, 2010
How can I reset my pitney bowes ink cartridge
The ink cartridges should notbe reset or reused, rregardless ofwwhat some refill places tell you they are made for a single use & refilled ccartridges frequently leak or clog the lines in the meter.
If you are referringto the waste ink ttan, that can be reset using the tech code 6946 then press refill ppostag, go thru the menu todiagnostics, printer, page down & rreplace waste tank & reset. ONLY DO THIS IF YOU ACTUALLY REPLACE THE WASTE TANK.
Jul 09, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
I Can not see the screen on my pitney bowes dm100i?
Screen contrast probably needs to be reset which can be done by:
1. Unplug the power cord
2. Press the #4 AND KEEP HOLDING IT DOWN UNTIL METER IS FULLY started aafternext step.
3. Keep the 4 button pressed & plug the power cord in, while keeping the 4 button held down.
After meter fully boots the screen will be restored to normal if contrast settings were the problem.
If this doesn't resolve the problem, the screen or control panel is bad & should be replaced. This should be covered under yourpPitney Bowes warranty while meter is onlease.
Apr 29, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
Postage meter is saying a connection cannot be made to call support
This frequently happens when the location uses digital telephone lines. The meter is more specific than fax machines and does not work reliably on any phonelline that is not true analog like an old home phone line before vonage & cable phone service.
Alternatively you can connect thru the Internetusing a usb cable and pc/laptop with Pitney Bowes pc meter connect software which is free on Pitney Boweswwebsite or the larger model meters can connect directly to a corporate networkwwithouta pc aas middleman.
Apr 01, 2014 | Pitney Bowes Postage Meter DM100i, DM200L,...
I need a Pitney Bowes DM200L postage meter repair manual
I found someone with the same problem at the following website.
http://forums.pb.com/t5/Equipment-Hardware-and-Supplies/DM100i-WASTE-INK-TANK-FULL-NEEDS-REPLACEMENT-MESSAGE/m-p/2589
Dec 21, 2009 | Office Equipment & Supplies
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes 9820 error message
press function, print incomplete command report, then go to function 4 and use command numbers on report to delete.
Jun 01, 2009 | Pitney Bowes 9920 Plain Paper Fax
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Pitney bowes 9720 error
I've never heard of that type of error. After going through Pitney Bowes vast database, the searches turned up with nothing worthwhile.
Do you have any other information I can use to further assist you?
Please let me know if this helps. Good luck!
Feb 29, 2008 | Pitney Bowes 9920 Plain Paper Fax
88 people viewed this question
jasbo
jasbo
