Question about Jacuzzi - Bathtub - Alcove - Navona - R105917
Jacuzzi Bathtup pump issues
The pump to our Jacuzzi bathtub is failing to operate. When it is turned on the pump just makes buzzing sound and if left on too long the breaker for the pump kicks off. There is no access panel to the pump so there is no way of get to it without cutting a hole.
Currently the tub is full of water and we are going to let it sit with the water in it or an hour our so to see if this will loosen anything up.
  • Jacuzzi Master
  • 717 Answers
Buzzing sound on a motor means it has almost burned out. you will need to replace the pump.
Posted on Sep 06, 2010
Jacuzzi tub will only turn off if tub is empty
This sounds like maybe you have a bad circuit on the control that turns the pump on/off.
Get the model number off the control box under the tub and let me know what it is and we can solve that issue for you.
Rod
US Parts Center
888-521-6183
May 03, 2014 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
The wall switch control for the Jacuzzi bathtub was left on for at least one week. Now the motor for the whirlpool bath will not operate. Could the motor have burned out? Tripping the reset switch did not...
pretty much bet on the fact that the pump has burned out. You are very lucky it did not set your house on fire. There is much friction when the pump is on and there is no water in the wet end to keep the seal cool. You will need a new pump. What model pump do you have? Find your Pump
Aug 15, 2011 | Jacuzzi Home
My jacuzzi bath tub makes a humming noise when I turn it on, but it will not operate. I tried again later, and still nothing, and not even the hum now.
Pump was humming, suspect air lock, pump could of burnt out, check power to pump and if it blows fuses then you will need a new pump and don't forget to bleed the pump
Jul 16, 2011 | Jacuzzi Home
I have a whirlpool jacuzzi tub. I wired to diagram but when tub is full and I turn on jets it trips a breaker. Not GFCI outlet but breaker panel breaker.
Sounds like you may not have a ground on the motor of the pump or a grounded outlet?
check the wiring on the motor on the cord to make sure there are no wires improperly attached inside the motor housing.
Jan 07, 2011 | Jacuzzi Amiga, Soaking Bathtub with...
What causes my jacuzzi hot tub to turn itself on.
sounds like you have an electronic system that operates the tub. Many times those get hit with a voltage spike and it burns up a relay on the circuit board and THAT is what make them come on at weird times.
You will most likely need a new control for your tub.
Jan 04, 2011 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My jacuzzi bath making a beeping sound and not working why would this be?
this sounds like a low water issue. Check the low water sensor on the bathtub and make sure it is attached and working.
Jan 02, 2011 | Jacuzzi Home
Jacuzzi whirlpool bath not working when i turn it on i get a buzzing sound
buzzing sounds tend to be a motor problem. You may need to change the pump. When you turn it on it just buzzes? that indicates a bad motor.
Dec 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Heater pump does not turn on Jacuzzi hot tub 325
You should be getting error messages like flo or FLO2. check the voltage to the pump from the board if power is there the pump is bad and needs replacing
Jun 12, 2009 | Jacuzzi Amiga, Soaking Bathtub with...
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Feb 22, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Jacuzzi - Bathtub - Alcove - Navona - R105917 Logo
201 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
