Question about Viking 31 in. DECU165 Electric Cooktop
Viking DECU 1655 BSB - Ceramic cooktop lifting up from stainless
The ceramic cook top is lifting up from the stainless steel border. Looks like there is a gasket of some sort. Maybe the top just needs to be re-glued to the metal border......
catriver
  • 878 Answers
SOURCE: Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Posted on Feb 26, 2007
watugot
  • 290 Answers
SOURCE: how to fix a crack in ceramic top
You will have to replace the top.
Check your owners manual, you should have a 5 yr warranty against cracks if it was not due to something being dropped on it or improper fit in the cabinet. The warranty will cover the top but you will have to pay the labor to change it.
You need to quit using it until it is repaired to keep spills from getting into the elements and burning them out.
Post back if you have any questions.
Posted on Nov 18, 2007
  • 1314 Answers
SOURCE: ceramic cook top popping up
from the counter top or the metal cabinet its in
Posted on Dec 30, 2007
jyackle5
  • 8197 Answers
SOURCE: I need to remove my Whirlpool Gold ceramic cooktop.
the safest way for a home owner to do this is turn the main breaker off to the house that is the safest way. Then poll the cover plate off the box in th wall with the two screws. not the screws on the round conduit. Then pull out the wire nuts that hold the wires together and un screw them to separate wires I would label them so you know what ones went together. After top is in just reverse the proses above.
Posted on Dec 16, 2008
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Homeā„¢ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
Viking cooktop DECU165-5B stainless seperated from
It can cause a fire. The same thing happened to me fortunately I ha dthe extended warrantee and it was covered. This is a common problem and should be addressed by Viking. After all it is not a cheap appliance.
Jul 21, 2010 | Viking 31 in. DECU165 Electric Cooktop
I have a dplomat APL13 ceramic hob in the house I just bought. Can I use it with any type of saucepan? I just don't want to start using my old saucepans, stainless steel or not, and find that they do not...
Yes you can use any sause pan on the cook top. You will not damage it at all.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 09, 2010 | Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
How to remove brown scorch mark on stainless steel cooktop cover
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Mar 26, 2010 | Jenn-Air JGC8536 Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Stains on black cermaic oven top
Use DeBruce Polish I guarantee great results, also perfect on stainless steel go to debrucepolish.com
Mar 06, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Discoloration of cooking surface (darkened) on Bosch stove
I'm Bruce of DeBruce Polish, our new polish is non-toxic and odorless and non abrasive, should take care of your problem. We designed it for stainless steel, and have faboulous results on ceramic stove tops, and chrome and many other uses. Even removes permanent magic marker. web site will be up soon debrucepolish.com. Phone 612-220-2236.
Jan 02, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Ceramic cook top popping up
Nov 28, 2007 | Viking 31 in. DECU165 Electric Cooktop
Viking ceramic cooktop numbers washed off
I have the same problem. The previous suggestions are assanine and have Cleary not actually read the question. The question is how to replace the original heat numbers that rubbed off.
Nov 14, 2007 | Cooktops
Viking 31 in. DECU165 Electric Cooktop Logo
321 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
