Question about Kodak EasyShare C613 Digital Camera
I turn on the camera and all it shows in the screen is colorful lines and mostly blocks of black. everything else still works on the camera but the screen is not visible at all to see what i am taking a picture of.
  • 4 Answers
You may have damaged your lcd screen. If the screen still lights up the your back light should be fine. You can go to www.thefotogeeks.com for a replacement lcd for your C613.
Posted on May 13, 2010
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
Anything to do for vertical lines on screen?
most likely a damaged sensor. How about the pictures? Do they show these lines on them too?
Oct 23, 2015 | Canon PowerShot ELPH 340 HS Digital Camera...
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
Screen is Black, light I'm in a dark black room black
Same problem as you described. I haven't figured it out yet.
Jul 20, 2008 | Samsung L700 Digital Camera
Display not showing correctly
I had the problem, got the CCD changed it worked for a few months then it stopped working once again. My advice, though its a great camera its time to retire it. Problem is I just love the ability to add on filters which is not common in most prosumer cameras
Jul 09, 2008 | Fuji FinePix S5000 Digital Camera
Projection defect
Good Day;
It sounds like you may need to re-adjust your G-2 controls, located at front, remove front panels. Look for small block with screen /focus controls on item, first turn color down, reset brightness, contrast controls. Adjust until lines are at min. and picture is a good black and white (grays). Good Luck, big IRISH.
May 21, 2008 | Panasonic PT-52LCX65 44" HDTV
Camera showing/taking distorted images
According to many respected sources with far more expertise than myself, the symptoms you are describing also fall within the realm of Canon CCD failure. In Canon's Service Notice: CCD Image Sensor Advisory, they outline the most common symptoms (distorted images, LCD showing only a black screen, etc.). They have conveniently limited the description to the bare minimum. More symptoms of the failing CCD include: pictures appearing on LCD show up with severe color variations (pink-purplish or green tint), colored "streaks" or "lines" throughout pictures, and wavy distortions in image. Most of these symptoms include the color variations, but not always. The lines or waves can appear in any direction and with varying degrees of severity. Some LCDs do not go black, but turn totally purple. Here is a link to a very informative article that should clear up any questions you might have.
Digital Camera Repair Blog
If nothing else, call the Canon Customer Support Center at 1-800-828-4040. They will ask questions to identify whether or not you are having the same symptoms as described in the Product Advisory. I have been through this twice, and both times they were very nice and very helpful. Even if you don't qualify for the free repair, it didn't cost a thing to find out.
I hope this has been helpful.
Nov 20, 2007 | Canon PowerShot S1 IS Digital Camera
Picture screen distorted.
Your LCD screen has been cracked, it will have to be replaced. The screen is actually made of thin glass, so what you are seeing is actually just like a cracked or broken mirror or window. This kind of damage is not covered by manufacturers warranty so I would suggest finding a repair facility online to service your camera if you wish to get it replaced. The replacement LCD should be somewhere from $60 to $80 and somewhere around $50 in labor. The problem with communicating with your computer is unrelated to the screen issue. Try again, and make sure everything is set up right. It is likely that function still works fine. :) David Millier Advance Camera Repair
Feb 17, 2007 | Nikon Coolpix 4600 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
