Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a John Deere X304 that mows unevenly.
I have a John Deere X304. It mows unevenly on slight elevations. I even have leveled the deck several times, is there something else I need to do.
    President:
  • 1,627 Answers
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
Posted on May 12, 2010
What size belt goes on john deere 214 deck
Go to Google type in John Deere lawn tractor model number then owners manual
Jul 08, 2017 | John Deere Garden
La125 john deere
Check the blades for true. If one is bent from hitting something that will cause uneven cuts.
Sep 08, 2014 | Garden
John deere 717a shut-off while mowing
Mine took a Poo this evening. It's a 717A Z turn and it's run just fine for 4 years but tonight it kinda Popped (like something broke) while under a slight load and then shut off. Oil level was slightly low and curious if I blew the engine. It still cranks just fine but won't fire off? Acts like it's not getting fuel but the filters are all clear and fuel flows. It's my Church's mower and the Blue hairs are gonna kill me if I blew the engine.............I'm toast!
Jul 30, 2012 | John Deere Garden
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My mowers cuts uneven I replaced the blades but it still cuts uneven how can I level it?
Park mower on a level flat surface ( a concrete garage floor is ideal ) lift deck up until you can put a piece of a 2x4 flat underneath the deck and lower deck until it just contacts the 2x4. loosen adjustment nuts or turnbuckles and adjust until the deck just starts to clear the 2x4. this should level your deck. Now , lift the deck and remove the 2x4. put blade height lever on a known cut length and with a tape measure, measure the tips of the blades from the floor to the blade tip...they should all be the same within 1/8 of an inch...if not then you either have a bent blade, bent spindle shaft, or spindle bolts are loose or misaligned. Your deck could be warped too...depending on how hard a lick it took...good luck !!! ;-D
Jun 24, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mowes unevenly. Blades don't match up.
make sure when you replaced the spindles that you used all the washers and spacer bushings back identical to the ones you took off.
Make sure your deck isnt bent for some reason where the spindles mount and or the deck itself
level the deck when its on the mower on a level suface,side to side(level) back to front the back just a little higher than the front 3/8 inch or less
proper air pressure in all 4 tires
Also you could add a washer or take away a waher to allow the blades to become level at mid point meeting?
be sure to torque the blade bolts to 35 ft.lbs also
May 31, 2009 | Husqvarna Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
890 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
