Jumper setting dear sir, i want to know the jumper number to disable the graphic adapter on board and plan to use an alternate graphics adapter on an add-in card.
  • 68 Answers
Amigo !
just tell me your main board name and model.
Posted on Mar 29, 2008
SOURCE:
Disable intergerated video card to allow for pci card to function
You need to access the BIOS to disable the on-board video. Do you have Windows 7 installed or have you upgraded to Windows 8?
For Windows 7, turn off the computer and then turn it back on. After pressing your on switch press Delete repeatedly to access the BIOS. (Some computers use Tab or another key, you should see a screen indicating the correct key.) If Windows starts to load, try again. (I usually have to try 3-4 times to press the key at the correct time following the POST.)
For Windows 8, the boot sequence can be too fast to hit the key. Use the Advanced Restart option. Access the Charms menu and choose Settings > General > Advanced Startup. Alternatively, Charms > Settings > Power > press Shift and then select Restart. This should give you a Boot options menu and you'll be able to access the BIOS from that.
On my machine, I need the Advanced BIOS and then the System Agent Configuration. Then I select Initiate Graphics Adapter. Your BIOS may be slightly different. Go through your VGA graphics for disabling the on-board graphics and enabling the correct PCI/PCI-e graphics option.
I hope this helps.
(make sure that your power supply will support the graphics card.)
Mar 17, 2013 | eMachines ET1331G07w (884483025329) PC...
HOW TOI DISABLE ONBOARD GRAFIC AND INSTALL NVIDIA GRAFIC CARD
fit the graphic card to your pci-e port of the mother board
on bootup press F2 to edit the CMOS/BIOS options
and disable the VGA graphics or noboard graphics there
ENABLE PCIE graphics.
save the settings
boot to windows
upon boot install new drivers for PCI-E card
restart the pc
Mar 04, 2011 | Asrock PV530 - 1.8 GHz processor - VX900 -...
Disable onboard graphics of my PCChips M825LU motherboard?
Yes its a BIOS setting that you have to change. Usually you change from on-board to AGP settings or plug the graphics card in, take out the motherboard battery and the power cord from the back, leave it for 20 minutes and put them all back again.
This will reset the BIOS and should auto detect the AGP graphics card. You will however need to set the date and time but you can do that from Windows.
Regards.
Jun 28, 2010 | PC Chips Computers & Internet
Proper jumper & BIOS settings for XFX 750aSLI nForce motherboard
You will have to access the BIOS and disable the onboard graphics from there. Before you install your new card, boot the computer. As it is performing the POST, enter the BIOS (usually delete or F2 gets you in.) Once you have disabled the on board graphics, save your settings and exit. Then install your new card and attempt to boot the computer. If it will not boot, locate the CMOS jumper and activate it to reset back to default settings.
Apr 05, 2009 | Computers & Internet
I have an emachines etower 433i with onboard video. I've installed a separate pci video card, but I don't know how to change the jumper settings on the motherboard to disable the video chip. On the...
Go into >my computer>properties>device manager>graphics.You should be able to disable your on-board graphics there. Be sure your computer boots from the new card before you do this.
Dec 17, 2008 | Computers & Internet
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
Graphic Card
jumper settings for old graphic needs to be disabled or in the bios settings the on board vga settings need to be disabled this will allow the other new card to be ran as the dominent only video card
jumper settings are tricky
but bios settings are easy just find vga and disable on board video thats it save and boot
Jun 04, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Mother board - video card compatibility
if you have a built in video on mother board there is a setting in its setup hit delete at beggining right at startup for bios
you need to disable your built in video either by jumpers by manufactures book on jumper settings or go into bios at begining and see if there a setting to shut off on board video
these 2 are having conflicts with each other and you will only be able to see dos boot area with both these cards
and yes it is compatible as long the buses and slots have same configurations
May 07, 2008 | Sapphire RADEON™ HD 2600 Pro, Graphic Card
On board graphics p4vmm2
This is the manual for your motherboard. Page 13 shows you which jump you need to reset to clear your BIOS. The jumper appears to be labeled JBAT1.
Hope this helps!
Nov 15, 2007 | EliteGroup P4VMM2 Motherboard
What graphics card this motherboard will support
Gigabyte did not put a special graphics slot (AGP, PCIe etc) on this corporate series board. It has good internal graphics support. If you would like to run two monitors, it appears that one choice is the CHAINTECH P-FX20 256MB Geforce FX5200 256MB 128-bit DDR PCI Video Card, based upon user reviews at NewEgg. You may need help getting both graphics adapters to operate together. Typically, there is a jumper on the card that disables "Primary VGA" mode. Your OS should boot using the on-board adapter and then you can tell the OS that it should "Extend the Desktop" to the second (PCI) adapter. Your results may vary.
May 12, 2007 | Gigabyte GA-8I865GVMK Motherboard
Open Questions:
avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7
Oct 17, 2019 | AVG Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
