Question about Acer Aspire 3680 Laptop
Mouse the built-in mouse on the keyboard is not functioning.0
  • 2 more comments
  • jimmy1091 Mar 29, 2008
    Dear Mr. Faheemsafdar
    Thank you for your suggestion. That's what i did in the meantime that my mouse is not functioning.
    I must have pressed some function keys that resulted to disabling the mouse. I'm hoping that someone would know how to solve this problem.
    Thanks again.
    Dear Mr. Faheemsafdar,
    I'll try your suggestions and let you know the outcome.
    Thanks again.
  • jimmy1091 Mar 30, 2008
    mewms_14904,
    FN key + F9 didn't work. But thanks to you because i tried FN + all the F's and WALAH...... FN key + F7 did it. I GOT MY TOUCHPAD WORKING PERFECTLY AGAIN. THANKS A LOT.
    MORE POWER TO YOU GUYS.
  • Norbie Ronsonet May 07, 2008
    FN + F7 DIDN'T UNFREEZE THE MOUSE
    UNDER CONTROL PANEL MOUSE DEVICE SETTINGS EVERYTHING WAS GRAYED OUT???
    STILL CAN'T GET THE MOUSE PAD TO WORK
    PLEASE HELP
    Genius:
  • 1,027 Answers
On my laptop the FN key and F9 activate and deactivate mouse
Posted on Mar 29, 2008
  • 68 Answers
If you want repair this it costs high. I suggest you to buy a "usb optical mouse". Just plug it in to you usb port on your laptop.
I think it better. Contact me again for any suggestion.
Thanks
  • Anonymous Mar 29, 2008
    I think there are two more steps can be taken.
    1. Try to reset the bios setting.
    2. Restore your operating system ( If you have Windows Xp or Windows 2000) setting with that date when you had freshly installed you drivers.
    If you don't know how to restore contact me again. Hope it works
SOURCE:
I cant get the mouse to connect to my laptop
Desktop or Laptop ?What type of mouse ??...
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Wireless Mouse to Your Computer & Laptop
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace. Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse. If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse.
If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware.
If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
http://www.sunvalleyus.com/Article/LaptopKeyboardInfo/46.html
also
Laptop computers generally have built-in pointing devices such as touch pads that you can use to navigate the operating system on the go.
However, touch pads and pointing sticks are small and generally far from ergonomic.
At home, you might like to connect a full-sized mouse for greater comfort.
Computer mice connect in a variety of ways, and you should be able to find a mouse what works with whatever peripheral ports your laptop has.
As a general rule, any mouse that works with a desktop computer also works with a laptop.Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs.
Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time.
Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard.
Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse.
This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function.
Press and hold the "Fn" button together with the mouse icon button.
Look for the disable/enable symbol that briefly displays on your screen.
Slide your finger over the laptop's mouse and attempt to use it as normal.
Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter."
Press the left arrow key to navigate over to the "Device Settings" tab.
Press the tab key to reach the "Enable" button in this section.
Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box.
Press the space bar to remove the check mark.
Put your finger on the touchpad, and move the pointer down to the "Apply" button.
Click "Apply" to save the settings. Close the mouse "Properties" box.
Press the keyboard "Windows" logo key to open the "Start Menu."
Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart."
Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function.
Open the "Control Panel."
Go to the "Add and Remove" or "Uninstall" programs section.
Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse.
Select the "Uninstall" option to remove any software and settings associated with this secondary mouse.
Restart your computer and attempt to use the built-in laptop mouse as normal.
Check to see if the mouse is working properly.
Press the keyboard's "Windows" button to open the "Start Menu."
Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel."
Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it.
Find "Mice and other pointing devices from the list" and open its "Properties" dialog box.
Select the "Driver" tab and choose "Update Driver."
Allow Windows to search the Internet for drivers and to update them automatically.
Restart your computer after the drivers are updated, and use your mouse as normal.
http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Aug 11, 2013 | Computers & Internet
Mouse didn't detected
Touch pad usb or wireless mouse ?
Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs. Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time. Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard. Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse. This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function. Press and hold the "Fn" button together with the mouse icon button. Look for the disable/enable symbol that briefly displays on your screen. Slide your finger over the laptop's mouse and attempt to use it as normal. Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter." Press the left arrow key to navigate over to the "Device Settings" tab. Press the tab key to reach the "Enable" button in this section. Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box. Press the space bar to remove the check mark. Put your finger on the touchpad, and move the pointer down to the "Apply" button. Click "Apply" to save the settings. Close the mouse "Properties" box. Press the keyboard "Windows" logo key to open the "Start Menu." Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart." Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function. Open the "Control Panel." Go to the "Add and Remove" or "Uninstall" programs section. Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse. Select the "Uninstall" option to remove any software and settings associated with this secondary mouse. Restart your computer and attempt to use the built-in laptop mouse as normal. Check to see if the mouse is working properly. Press the keyboard's "Windows" button to open the "Start Menu." Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel." Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it. Find "Mice and other pointing devices from the list" and open its "Properties" dialog box. Select the "Driver" tab and choose "Update Driver." Allow Windows to search the Internet for drivers and to update them automatically. Restart your computer after the drivers are updated, and use your mouse as normal.
Beginners Guide to Using a Computer Mouse? Tips and Tricks
http://tips4pc.com/basics/beginners-guide-to-using-a-computer-mouse-tips-and-tricks.htm Laptop not working - touchpad unresponsive http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 14, 2013 | Acer Computers & Internet
Windows update = dead mouse
Try using a usb mouse and keyboard.Your computer should already have drivers for these devices loaded.
Apr 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Mouse and Keyboard are dead
plug in an external keyboard and mouse the  go to the control panel click mouse the select the built in and click enable go back and do the same thing with keyboard
Jul 13, 2009 | Computers & Internet
Keyboard & Mouse
Make sure that the keyboard wire is plugged in to the keyboard port and mouse wire is plugged in to the mouse port. Remember that you need to restart the system once after you plugged into the motherboard. if that doesn't work then replace the keyboard / mouse and check. if same thing is happening then there is a problem in your motherboard. Thank you.
Sep 09, 2008 | ASUS P4P800SE Motherboard
MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Aug 08, 2008 | Microsoft Wireless Optical Notebook Mouse...
Bluetooth Mouse problems
There may be wireless interference. Do you have a bluetooth cell phone?
May 01, 2007 | Logitech V270 Mouse
Acer Aspire 3680 Laptop Logo
77 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
