Question about Kenmore 57029 Side by Side Refrigerator
Lights went out on frige side, replaced and they still will not work
  • Kenmore Master
  • 1,606 Answers
You have a bad control board , which also makes the temp adjustment lights work also . This board , is located behind the refrig , at the bottom left , inside a plastic holder ( 2 screws hold it on ) . Costs about 80.00 , and easily replaceable .
Posted on May 12, 2010
Freezer is cold 0F and frige is warm 70F
cleaned it and door was open for a while. closed door and and an hour later alarm went off. alarm now flashing and alarm light still on. temperature now at 53. freezer 33
Feb 01, 2010 | Maytag MFI2568AE Side by Side French Door...
Whirpool gold Frige no light or temp display working
I am having the same problem does anyone have a solution?
Dec 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have water going through the water dispenser, but no water going into the ice maker. The infrared light seems to aligned with the receiver.
The water inlet solenoid on the back of frige has two valves that never go out at the same time. Follow the supply line to the solenoid. Turn off water supply, unplug frige and replace part.
Nov 06, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Refrigerator cooling problems
the control board is famous for not working --first check that the lights in the frige are shutting off when you shutb the door are the doors at the same height or is the frige door 1/4 to a 1/2 lower if so the door can be raised back by screwing the cam back at the bottom hinge
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side is fine but frige side is hot
the fridge side light bulb may be staying on,check door light switch
May 02, 2009 | Maytag MSD2656G Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Control panel inactive
Your refrigerator is in demo mode. Review your manual on how to remove it.
Feb 24, 2008 | Samsung RM255LASH Side by Side...
GE HotPoint HSS25 not cooling, but interior lights are on
video on troubleshooting
http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
if after you try the things on the video you may have to replace the motherboard. you can reset the frige by unplugin the power and pluging it back in. If you decide not to replace the motherboard as the unit will work fine untill you press the dispencer i reccomend unplugging the dispenser unit at the top of the freezer door so the frige will not accidently shut down just unplug the connector leading down the door. your frige will work fine without this connection just no water or ice at the door. If your frige is still under waranty (1year parts& labor) call them up and they will fix it.
The motherboard on this frige seems to be sensitive to surges and the transformer for the ice/water dispensencer goes bad. repacing the motherboard corrects this problem they cost about $75 to $90 on the appliance websites to install the new one it is very easy and you need to unplug your fridge and pull the metal cover off the back of the unit by removing four screws. the cables are all different size and can not be pluged in wrong the replacement board should come with instructions. to remove the board you may need needle nose pliers to push in the tabbs on the white board standoffs it should take about 10-15 minutes
I have solved this problem by replacing the back board if you have any questions I can help out
Jan 21, 2008 | Hotpoint HSS25GFP Side by Side...
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
See if you accidentally unpluged or damaged any wires under the refer during the move. There are connectors that can sometimes easily pull apart if a dolly hits them.
Dec 17, 2006 | Samsung SRS20DTD Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
