Question about Boating
1985 bayliner Volvo Pents 125hp 270 tilt/trim
I'm looking for a good used or even new cheap power tilt and trim for 1985 volvo penta 125hp 270 out drive???. thanks...
  • 2,926 Answers
Ebay will be the place! Especially this time of year, sellers will be getting rid of good parts. You will have to search the listings very frequently to see what comes up from day to day.
Posted on May 13, 2010
My volvo penta 270 keeps stopping it will work sometimes then it wont have repalced both relals n switch when u reveres the wires it works
Hello Kelly,
Are you sure the wires are correctly connected?
An electrical schematic will confirm the correct termination
points for each colored wire.
What wires are you reversing?
Aug 30, 2017 | Volvo Cars & Trucks
Bayliner boat cabin cruiser 1986 26 ft with gm motor and volvo penta carburator Need owners manual
What engine? 4cyl, 6 cyl, 8 cyl? 2.1 2.3 2.5 3.0 3.8 4.3 5.0 5.7 7.4liter?
Jul 31, 2017 | Volvo Boating
How do I find where the hydraulic pumppower trim is on a Volvo penta ad31 boat motor
Mounted to the inside transom. Usually on the starboard side.
Oct 16, 2016 | Volvo Cars & Trucks
Volvo penta wiring diagrams
Go to boat manufacturer and ask. However you might first check your ground connections at the motor and at the dash for corrosion or just loose.
Jul 14, 2014 | Health & Beauty
I have a 1985 bayliner with a 125hp volvo penta with 270 outdrive... i have 2 Q's 1. today the boat overheated pretty quickly, i think the thermostat has had it. after talking with some local boaters they...
It could be the thermostat is stuck in the closed position, but if you hear a troubling noise coming from the outdrive, I suspect the water pump impeller that is located in the outdrive is in need of replacement. A bad impeller in the outdrive will not assist in pumping water up to the engine, and will cause an engine to overheat quickly. The rough sound could be directly related to the impeller also, but could also be a different problem with the u-joint assembly or another outdrive internal component. Overheating can be caused by several things; Defective outdrive impeller, defective thermostat, clogged riser or manifold, defective engine mounted water pump assembly. These are the most common areas, but since there is a noise coming from the outdrive, I would concentrate trouble shooting this problem starting with the outdrive impeller assembly.
May 25, 2010 | Boating
I'm trying to figure out if my 1985 bayliner with volvo penta 125hp has power tilt/trim on it???
It should have power trim. In the engine compartment, either on the left or right side you should see a hydraulic pump with a tank to hold the fluid. There will also be hoses running to and from it. There should also be a switch at the helm that allows you to raise and lower the drive.
May 12, 2010 | Boating
Volvo penta 740 lower unit will not go down.
Kind of sounds like the trailer switch is in control. Many of these switches have lockouts and if you move the outdrive past the trip point the other solenoids are dead. Watch fingers. There may be a tilt switch on the water side of the transom in the pivot housing.
Jun 26, 2009 | Boating
Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
Mar 28, 2009 | Boating
Boating Logo
583 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
