Question about ViewSonic E70 17" CRT Monitor
ViewSonic E70 VCDTS21569-3P. NO POWER
PLS.. help NO POWER ViewSonic E70 VCDTS21569-3P, I tried to resoldering it worked in half hr. it's go bak to same problem NO POWER, plss.. Help me..
Try checking capacitor on the B+ line.
Posted on Apr 10, 2008
Try to check capacitor on the B+ line leakage.
Our kenmore elite he3 belt and spring came off..my husband replaced it and upon turning the machine on, the power switch just dinged..no lights...and the door is locked! We tried unplugging for an hr..he...
Sounds lik a loose connection... E70
what you need to do if you are comfoable. ( best with certified spark tbh) is unplug machine nd check all connection internally are secure with no 'pulled' wires or pulled electrical connector clips. This may have become loose when replacing bebelt good luck
Apr 15, 2014 | Kenmore Elite 45986 Front Load Washer
Sanyo 42 inch tv model number dp47460 turns off after a half hour
Hello
Check its power regulator board's soldering points for any loose solderings. Resolder all the suspected solder points by applying a little more solder.
Mar 05, 2012 | Sanyo 42 in. LCD TV
Poping up settings automatically
you have to open the back cover and first clean-up the pcb by sucking all dust use a vacuum cleaner check the microprocessor IC clean the area by soft brush then resolder if necessary. check the PCB.
Sep 06, 2009 | ViewSonic E70 17" CRT Monitor
While cleaning must have hit a button, everthing is upside down and can not figure out what to do, HELP
try hitting the ether these combination of Key's to flip the screen back
combs
ctrl+alt+down arrow
ctrl+down arrow
alt+down arrow
if down dosnt work the replace down arrow with up arrow hope this helps
Jul 30, 2009 | ViewSonic E70 17" CRT Monitor
I HAVE VIEW SONIC E70 ,IT IS WORKING FINE BUT WHEN I TURN OFF THE COMPUTER IT IS NOT AUTOMATICALLY SHUT DOWN,I HAVE TO SHUT DOWN THE MONITOR ALSO THIS PROBLEM IS ALSO OCCURS WHEN I TURN ON THE COMPUTER .
Possible Solution: Your Computer may have not configured the Monitor properly, to check, go to Start menu and Right click My Computer and select Manage then when Computer Manager is open go to Device Manager and find your Monitor and check if that device is working properly (right click on Monitor and go to Properties). Hope I helped - donman92
Jun 09, 2009 | ViewSonic E70 17" CRT Monitor
Viewsonic e70
viewsonic monitors are good for about five years then they are a fire hazard
May 14, 2008 | ViewSonic 17" CRT Monitor
Problem with 17" ViewSonic Monitor
The same problem w/ my viewsonic E70 17" monitor.The viewmeter or viewmatch color on screen do not appear when power ON, although the green led power is ON.
But if you rest your monitor for about 10 hrs or more the viewmeter will appear when you power ON the monitor.
You can now start your CPU.
Remember : No viewmeter screen on monitor when power ON, means no supply coming out the picture tube or high voltage.
But if there is Viewmeter on screen , this normal and OK>
Feb 04, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic e70
high resolution may selected press f 8 f 8 contineusly when pc initially on then highlight on safe mode you will see the display
Dec 27, 2007 | ViewSonic E70 17" CRT Monitor
Viewsonic E70 - Menu Popup
This is a builti n feature on the monitor of course- not PC driven
A repair is not likely
Buy a nice new Flat screen
Oct 25, 2007 | ViewSonic E70 17" CRT Monitor
ViewSonic E70 17" CRT Monitor Logo
180 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
