Question about Uniflame FG2204C Grill
Why wont my burners light up with a new propane gas tank
    Guru:
  • 1,051 Answers
Some grills have a safety gas shut off if a leak is detected. Suggest you turn gas off disconnect connections then reconnect and check connections with soapy water. When turning gas tank on open valve very slow.
Posted on May 12, 2010
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
No sound of gas
Tyrn off tank open conrtol knobs to burners , turn off burners turn tank on slowly see if gas comes out now , if not check burners are not blocked or injectors are not blocked
Jul 04, 2012 | Grilling
Burner igniters spark but do not ignite the burners. Do I need to replace them or is there some way to clean something. Also, the rotisserie burner will not ignite, and it has never been used.
All the ignitors work (spark), but none of the burners light ... is usually caused by and inadequate gas supply. Since you didn't didn't mention what the grill is fueled by (Natural Gas or Propane Gas), I going to assume it's Propane. So, turn the propane tank valve to OFF and disconnect the hose from the tank, Wait 5 minutes and reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow) , until it's fully open. Try lighting the burner farthest from the tank first. If it lights properly, turn the burner knob to the highest setting and continue to light the remaining main surface burner(s) the same way. If all lightt and the flame height is as it should be, you solved the problem. If it doesn't, either your tank is empty or the grill hose/regulator assembly needs to be replaced. You can purchase one from any home center or hardware store that sells gas grills. Take your old one with you for comparison.
If it's fueled by Natural Gas, make sure the gas line shutoff valve is turned ON all the way.
Hope this helped you to solve the problem.
Apr 01, 2011 | Ducane 30400040 Stainless Steel Grill
New propane tank won't ignite
The regulator on the on the hose is either gone bad, or could have got a little bit of dirt in it. You could tap the side of the regulator gently and sometimes this will solve it.
Apr 11, 2010 | Char-Broil Designer 463261106 Grill
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
No gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Sep 15, 2008 | BBQ Guys BBQ400C/G42 Grill
Jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
Jan 21, 2008 | Grilling
Uniflame FG2204C Grill Logo
446 people viewed this question
Top Uniflame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
limabeenie
Level 1 Expert
Are you an Uniflame Grilling Expert? Answer questions, earn points and help others
