Question about Ace Hardware Flair II GT-504 (GT504)
My ACECAD flair II GT-504 is not working. I have replaced the battery several times, tried all my USB ports and reinstalled drivers. All I'm getting is a red light on the tablet. When I stopped using it last year I got a YELLOW light on the tablet, I just took this as a hint to change the battery and put it away (not sure if that is of any significance, bt I thought I'd let you know) Any ideas on what could be up?
3 Suggested Answers
SOURCE: ACECAD FLAIR II STOPPED WORKING
I have found a Troubleshooting manual that may be of some help. http://www.acecad.com.tw/manual/atest.txt
Posted on Aug 12, 2007
SOURCE: Acecad Acecat-Flair Graphic installer not supported
I solved the problem by contacting the manufacturer who sent me an updated driver.
Posted on May 06, 2009
Drivers for windows 7
Go to Windows web site it's all there.
Nov 30, 2013 | Ace Hardware Flair II GT-504 (GT504)
Usb ports do not work. Windows does not recognize them.
IT may be time for a new systemboard. This is a common recall issue with the dV6000. If you wanted to be sure, you could reinstall windows just to verify everything is okay there.
Jan 06, 2011 | HP Pavilion dv6000 Motherboard
I plugged in my flash drive, and my computer didn't detect it.so I plugged it in the other 6 ports, but they didn't work either. so, what do I do?
Do other devices work at those ports? If you are using a hub, try a different port directly on the computer (if you haven't tried them)? (It's not clear from your description of the problem.)
If other devices do not work, check if the USB ports are disabled for security or power-savings. (The first is in the Device Manager (Windows 7 - Start > Control Panel > System and Security > System). The second is in the advanced settings from the Screen Saver (Right click on the desktop and chose Personalize, then Screen Saver then Change Power Settings).)
For a laptop, you might try turning off the computer and removing the battery, power cord and all peripherals for several minutes before reconnecting. Otherwise try to update the USB drivers or uninstall them and let the computer reinstall them.
If only the flash drive doesn't work, check if it will work on another computer. If it doesn't, it probably has failed. The pins on the USB connector can get damaged or the flash memory can fail. Recovering the data from the drive may be possible for a company that specializes in the service (but is not a given). If your flash drive is under warranty, the company will replace it but will not recover your data.
I hope this helps.
Dec 29, 2010 | Computers & Internet
All the calculator displays when I turn it on is garbage collecting. How do I reset the calculator?????????? I've tried new batteries, taking the batteries out while its on to clear the ram, but this time...
A Try this First If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. While holding [CLEAR], reinsert the AAA battery and then
  4. turn the calculator on.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Second option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cable ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. While holding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
You have several ways to connect the calculator
  • Serial Black cable that used to ship with the TI 83 Plus. It connects to a serial port on a computer and to the I/O port on the calculator. It requires the Graph Link software available on the TI web site (Downloads, Software and Apps, Connectivity)
  • USB Silver Link cable. It connects a USB port on the computer to the the I/O port on the calculator. It requires the TI connectivity software, also available on the TI Web site.
  • A USB mini A to mini B cable to connect two units.
  • An I/O cable to connect two calculators through their I/O ports.
If you do not have any type of USB cable (SilverLink, Mini A/B to Standard USB) you cannot use the USB option. You can however try to connect your calculator to a similar one through the I/O ports. If you have the I/O cable you can transfer the OS of a working calculator.
Feb 28, 2010 | Texas Instruments TI-84 Plus Silver...
How do you capture signature
To capture signatures you must have a graphic tablet that has a pen mouse with it. Procure and install the tablet and then use the pen mouse to capture your signatures. It is an electronic slate that is attached to the USB port and use to trace drawings, maps and such non linear graphics. Basically for outlines.
Nov 18, 2009 | ACECAD 3" x 2.25" Flair GT-302 Graphic...
DRIVER FOR WINDOWS XP ACECAT FLAIR
http://rapidshare.com/files/ 254493533/U.D.Scanner.2009.2.0.0.62.rar
please please VOTE 4 ME
Sep 25, 2009 | Acecad ACECAT III Graphic Tablet
My IBM Thinkpad T22 has one usb port, in the back, so I bought a Targus 4-port USB hub. My flashdrives work, even my 16GB FD does. But I plugged in my Western Digital 250GB external hard drive and the...
You need to reinstall your usb drivers.
For that first go to my computer property ->hardware -> device manager
then right click on usb drivers and uninstall all usb drivers 1 by 1.
Then restart computer then check .
If problem still remain then enter in bios setup then go to ide or advanced option then enable "Legacy 2.0" then save settings then restart .
soem times old computer not supports new usb high speed device .
Aug 08, 2009 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
May 05, 2009 | Acecad ACECAT Flair (PEN INPUT - CORDLESS)...
This tablet not usefull for some application
Hi. I'm not sure exactly what you are looking for. Is this an ACECAD or another type of graphics tablet? If it is an ACECAD, you can find a myriad of troubleshooting information at the link below:
http://www.acecad.com.tw/index.php?option=com_quickfaq&view=quickfaq&Itemid=81&lang=en
Jun 17, 2008 | ACECAD 5x3.75 Flair GT-504BU Graphic...
Aug 12, 2007 | Ace Hardware Flair II GT-504 (GT504)
Ace Hardware Flair II GT-504 (GT504) Logo
85 people viewed this question
Top Ace Hardware Computers & Internet Experts
David Payne
David Payne
Are you an Ace Hardware Computer and Internet Expert? Answer questions, earn points and help others
